Gender
Not Telling
Location
Sacramento, CA
Interests
metal fab, hauling rump roast
Occupation
Engineer
Biography
Revv it up, blow it up
Vehicles
91SS- WAI, NOS, vf39, etc
BoostedBalls's Achievements
Subaru Fanatic! (6/11)
10
Hello everyone! I haven't posted in a while as my car has been sitting for a couple years. Now the car is for sale and I would like to fix a couple of minor issues first. The large triangular trim pieces behind the rear doors have broken clips and I'm not sure where to find replacements. any ideas? Black 1991 Legacy SS. 190k on stock closed deck long block, AEM FIC, VF39 turbo, pink STi injectors, full stainless exhaust, STi struts and springs, black WRX seats, water to air intercooler, wet NOS system, H2O injection. Alloy wheels. Fast, fun and reliable. Located in Sacramento, CA
My 2011 Legacy 2.5i suspension has been squishy since new. I had a 2013 Legacy and the suspension was nice and crisp and stable. My question is- what models/years can interchange with the 2011 Legacy? Not about to spend a grand on my DD suspension. I upgraded my 1991 Legacy turbo with 2004 STi suspension and it is awesome. Does the same concept apply with the newer generations??? How about the seats? I upgraded the 91 Leg to 2004 WRX seats. I've been out of the game too long. What will fit my 2011 Legacy??? The stock beige seats stain if you spill water on them, even when new. I have shampooed them many times and they seem to stain while drying. WTF? There must be some under layer that is bleeding through to the top.
You called it! The pads I took of were worn unevenly and there was no cushion on the back of the pads. The parts store gave me the wrong pads so I had to reinstall one side. I smeared a little hi-temp RTV on the back of the old pads and that made the noise go away on that side. Now I have some ceramic pads in there. It's funny though because this is my first encounter with ceramic pads and they were not hard like I was expecting. The friction material was actually soft. Soft enough that I could scrape quite a bit of it off with my fingernail! I wonder if the heat makes them cure or something. ??? The braking seems fine. There is still some jingling sound coming from the front and I'll bet it's the exhaust shrouds. I'll tack weld the seams together and see how that goes.
Well, the more I drive it, the more I'm thinking it's the exhaust shields. It really sounds like very thin metal jingling around. I'll try welding the exhaust shields or remove them and see how that works out. The clamps are bottomed out tight already. I also noticed that it sounds and feels like the exhaust hitting the underside of the car when I first start the engine. Engine mounts? The trans mount is new.
My wife's legacy GT has 200k miles and the front struts or calipers seem to be making some jingling noise when I go over slight bumps in the road. The struts perform beautifully and the car handles great. The issue seems to lessen slightly when I am braking. The sound is coming from the front end. Struts? Calipers? What? It sounds just like a tambourine, no kidding... Her exhaust heat shields make noise but I don't think they are making this noise.
91 Loyale front hub castle nut. HELP!!!
BoostedBalls replied to broncolouie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
With the car on the ground- Have someone hold the brake pedal down, HARD. Then use a long pipe or something over the breaker bar(at least 4 feet). The threads are normal, not reverse. Turn the nut counterclockwise to loosen it. Having someone hold the brake pedal down keeps all of that torque from seeing the cv's, trans and differential. -
I guess I'm hijacking this thread, sorry. Hopefully this will be usefull to someone in the future... I found a single black connector under the dash but I don't see the other end to plug into. The code-pulling procedure is useless without the connectors being plugged in. I have the dealorship installed remote door lock unit crowding up a lot of space under there also.
Is there a schematic for the wiring harness of the 97 4EAT somewhere on here? I think the "mechanic" screwed up the wiring when he did the head gaskets. Now the car has torque bind big time. I get 16 flashes. The AWD fuse does nothing and GM limited slip additive does nothing. I doubt it's a coincidence that torque bind showed up when we got the car back from them. I inspected the wire harness and it seems fine. I guess I can pull the rear section of the driveshaft, but that's just lame. I gotta do something, the roads are drying up and this car drives like crap now.
Sadly, it sounds like the rings in that cylinder are shot. Now, the compression only seems a little low in that cylinder, the oil in that cylinder is most likely giving you a higher than actual reading just because the oil is helping to seal the gap or crack or whatever the case is. You need to get a "leak-down tester", the standard compression test is not going to help you much here. Check out this link: http://vmaxoutlaw.com/tech/leakdown_tester.htm keep us updated!
WCSS 11 Date and Location!
BoostedBalls replied to WCSS's topic in Meet n' Greet. Your USMB Welcome Center
I'll be there this time! (unless my car does not make it back from Bonneville Speed Week earlier in August. -
My wife's 97 Legacy GT 4EAT seemed to develop torque bind overnight. I put the fuse in expecting to get rid of the torque bind and run 2wd until I can fix the real issue. Well, I put a fuse in and it is still in 4wd. The fuse isn't blown. I also have CEL codes for: Throttle position sensor, knock sensor, misfire in #1,2 & 4. I wonder what is really going on here. any thoughts? I'm gunna change the spark plugs and check the TPS for resistance and maybe replace the knock sensor with one I have laying around.
That RR bearing seems like a problem to me, especially if you have aluminum wheels. They will pull the heat out faster than steels. BTW- the driveshaft will ALWAYS spin if the car is in motion. Regardless of the fuse for the transmission. It is directly connected to the spider gears in the rear diff and then to the tires. You could remove the driveshaft and clock it 90 degrees out from original to see if the noise and vibration changes. my $1 is on the wheel bearing though.
