Everything posted by peacewize
anyone ever put an ej 5 speed transmission in ea body?
peacewize replied to peacewize's topic in Subaru Retrofitting
I was wondering about how the axles would work out. Preferably I do not want any sort of hybrid axle. Everything I do to this car has to be replaceable with off the shelf parts. -
That's what transmission I have right now, fyi the low range is disappointing compared to the standard dual range. But I'm still using the same driveline no need to modify it to fit at least. -
Not entirely sure on terminology but they are "stack" fit.? I've found several people that have replaced them with u joints with the inside clips but technically speaking they aren't serviceable -
Awesome thanks. Little good news little bad news, turns out it wasn't my transmission making noise it was the u joint behind it. Figured this out when it finally snapped and the driveline started making a mess of things. Easy enough fix but apparently Subaru doesn't have serviceable u joints... -
I'm in the Seattle area and my trans is making some death growls so I need an immediate fix no time to rebuild. The main reason I'm asking is because theres not a very good list of gl's at the pnp's so if I have to go newer o want to know what I need to make it work. Been searching online for info but without much luck. -
I have a lifted 88 wagon with a 2.5 swap in it and currently have an AWD dual range transmission for an 87 rx i think. On my way to the seattle area my transmission begin making some death growls and i need a replacement and want to know what parts would be needed to retro a newer transmission into my car if thats the only option.
87 rx 5spd trans questions
peacewize replied to peacewize's topic in Old Gen.: 80's GL/DL/XT/Loyales...
ya full time, thats a pretty neat conversion. Still trying to find those O rings if anyone happens to know anything please help! -
its the best tear down ive found so far and i figure the torque specs and stuff should be similar enough. So far ive sourced all the seals except the two o rings on the front. the large one that you can see above and a smaller one which im assuming is on that shaft you mentioned because its not listed above. as far as swapping gears i think im going to hold off for now and just reseal this trans. later on i think ill give a shot a making a hybrid trans. If anyone has any info/ part number for the orings please let me know. These two orings are the only things holing me up from getting my car back together haha -
I have this hear and a bunch of stuff for torque specs gear ratios et. Kind of hard to make out, like i said first time doing this and im really excited to figure out how this actually works. Which gears exactly change for low range? ive been playing with it and i think i figured out how the gears 1 through 5 work but the low range and diff lock thing dont quite make sense yet. Also its from a turbo rx so it already has the larger stubs. Thanks -
hey all, first time rebuilding a manual transmission and am a bit nervous about getting it back together. all the gears and bearings look perfect (low mileage trans) so basically just resealing it. However I would like to swap in the 1.59 low range set from a gl d/r but im not sure which parts I need. Been searching for rebuild procedure but haven't found anything. Mostly i need the torque specs/ sequence for the case bolts and any other tips you guys could chime in about putting it together would be great. Thanks!
10 years? Thats the kind of information I am interested in. As you stated people move on and stop using the forums so finding this information is very difficult. Tons of threads of people getting or modifying things but the thread dies before you find out how the mod worked out especially long term function. Not everyone is diligent about updating information. To date the only negative comments about Delta was a few (very minor) issues in communication or shipping but that can happen with any company. Nothing negative about their product itself which is a very good sign. I know they have been used a long time and Im not trying to bring up a dead subject I just don't like basing my decisions on popularity. Your right it is an assumption either way, Im most likely going to do it but I will be suspicious for at least a little while after I have my engine running again. What Im particularly nervous about is this is my first full engine rebuild so i just want to get all my facts straight instead of slapping it together and hoping it works. Thank you
i don't need to google search i have research this topic for over a year, my issue isn't how many people have used them. Although the mass amount of people using them would be a good indicator of quality, I don't like to make assumptions. Most people post about getting them or putting them in various applications however I cant seem to find anyone saying they've had them for any extended period of time which is what Im most concerned with, longevity of these cams.
SOHC NA EJ25 2001 forester. Looking to get some camshafts for it and have been considering delta 1500 regrinds however I have some concerns about my camshafts being welded on. Two questions: Has anyone had any troubles with going this route? Cam failure? Im interested in hearing from people who have had them on for a while. Second question is there any other options for cams besides regrinds?
i think i just cut it to fit the tray in and jb welded it in place to the adapter
Ya i think i stole it out of a early 90's legacy. I have another cd player adapter if your looking to get one
thank you. Just finished the rear disk swap, got very lucky finding the backing plates so easy. Just wanted to show for anyone thinking of doing this you don't need the rubber line going to the caliper if you don't mind disconnecting the hard line anytime you need to remove it. You can re bend the old hard line straight to the caliper. Also if anyone is interested the part number for the new lug studs is 610-276. Its a 12x1.50 so you have more lug nut options
haven't updated all year. Quick over view. Finished my ej swap last spring was amazing until i jumped timing this summer. Working on rebuilding it now. Lots of pics to show some stuff I've done. All the trim inside from the doors up have been removed. All the wiring was pulled and ran through the roof channel. Sound deadener was put in the doors and roof, LED dome lights front and back. The antenna was pulled and a small power antenna was put on the dash. Turned the lower pocket into a gauge pod. Swapped in an AWD D/R 3.7 trans and matching diff. Found Some 15" Allied Armament rims in Oregon. Converted all the lug bolts over to a 12x1.50 style so I could put different nuts on. UEL Headers half wrapped and coated. Flowmaster super 40 series muffler. 2" lift Using tempo/ accord/ toyota setup new shocks all around. Rear disk brake conversion (will be finished this week) Rebuilt calipers ceramic brake pads. K&N Apollo filter. Front seats swapped from a 2007 KIA Rio, bed lined the door panels, new axles, new wheel bearings. Tinted windows, painted hammered finish black, New EJ radiator and dual 12" fans. Im sure Im forgetting something but any questions just ask Check out my photobucket for the rest of my pics Im only going to post the highlights here.
Thanks for the tips ill have to research the glass beads in not familiar with them. Anyone know what gear/ gears I would need to lower my low range? I'm going to pick n pull tomorrow. Pictures would be very helpful thanks
if memory serves me correctly it engaged about 1/3 the way up from the floor. I believe its the syncros because the transmission is a low mile (around 80k) trans but it had been sitting for a number of years. When I first installed it I ran it with some cheaper synthetic oil for about 500 miles and then drained it and put in the fancy subaru oil, didn't make a difference. I'm definitely serious about doing it but I would like to assemble a parts list ahead of time and have been having trouble finding anything beyond basic seals. I dont want to gut it and find out I cant get parts for it basically
I figured while i got the engine out maybe i could pull the trans again and clean it up a bit. It's a dual range awd with 3.7 gears from an 87 rx turbo. There are two issues with it i was hoping to address and maybe someone here can point me in the right direction. The first is it didn't go into any gears very smoothly, like you had to get the road speed and engine speed lined up pretty close or it wouldn't really shift into gear. As you can imagine this made for some difficulty when bombing up a hill and needing to drop a gear really quick. The second is I don't feel the low range is low enough. I've seen threads that people swapped in a lower low range gear set just wanted to know what specifically i can pull that from to have the lowest possible low range.
too late to franken swap?
Thanks for the info. I'm I bit disappointed that it's hardly a noticeable difference, of coarse in retrospect most people start with the 22 or whatever they had stock so it would be a major bump for them. I think I'm just going to do cams and.call it a day.
