3
Everything posted by Dinky26
so no regular stereo fits the Brat dash?
Dinky26 replied to odie's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm thinking there would be more depth available if one was to put it at the bottom vs the top like mine is. However mine is probably only on a 1/4" spacer behind the front plate. -
I guess I'm one of the lucky ones then, mine was originally a Cali resident. Once it warms up I'm going to work on getting it installed. The wife still doesn't know why it is needed, oh well going in anyway:)
- 11 replies
- cruise control
- Gen2 Brat
(and 1 more)
Tagged with:
Freezing coolant(water) killed my car?!
Dinky26 replied to 82GLWag's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Unfortunately this seems to be the most effectively way we (HUMANS) learn. I've been fairly fortunate in that I have not destroyed an engine over the years, I had my BIG brother to learn from there ... He changed the oil in dads pickup, (one that my brother drove at the time) well....he changed it all right, just neglected to put the drain plug back in :o ...Dad forced him to assist with that engine rebuild, he hasn't gone with out putting the drain plug in SINCE ...OOPS. About 5 years later I totaled that truck, broke my back and 4 or 5 ribs :banghead: , funny I was more :mad: about the truck then I was about my back or being in the hospital for some quite awhile. I still miss that truck too, 76 Chevy Scottsdale still makes me :( from time to time. So yeah, kind of a hard learning experience for some from time to time. I am willing to bet you won't do this same thing again. -
awesomeness, thanks for input of knowledge!
- 11 replies
- cruise control
- Gen2 Brat
(and 1 more)
Tagged with:
Is it possible to install a Subaru Cruise Control unit in a Gen2 Brat GL? It is labled to work for all GL models. Just wondering if it is possible now that I have converted it with a Weber Carb. If not then I will be looking to sell it.
- 11 replies
- cruise control
- Gen2 Brat
(and 1 more)
Tagged with:
That surely won't improve your mileage in that state.
I would say it is all depends on what your passion lends to. If it were me I would lean towards doing the swap, I am assuming you have the EA71 presently in. Would present so much more power....AWESOME!! However if you are in for a change (ie; different style, setup of vehicle) then you might want to consider selling, or you could buy another vehicle to make a go between funds permitting of course. However sounds like you have a fair amount of attachment to your first Subaru, I personally would find it very hard to sell as well, thus if it were me I would probably keep it just IMO. At the present time I seriously doubt that I will ever get ride of my Gen2 Brat, however one never really knows what is down the road for any of us. I really just enjoy driving it way to much I JUST LOVE IT TO DEATH!!!!!!!! Kinda of just a matter of personal preference IMO.
I think I may have the old style radio and tape deck setup in the load of stuff I bought, if you are interested. That being said, the PO that I bought my Brat from, put a CD player in and KNOCK on wood I don't think it has ever skipped on me! and I listen to the CD quite a bit, much more than the radio. -
In the process of converting my drums to disks, I noticed the seam around the middle of the Reservoir starting to leak. Anybody know where one can get another Reservoir and not the cylinder, especially when they sell the cylinder without the Reservoir?
Yep, don't blame you there. Thanks for your input. I'm thinking I might order a pair from Rockauto price of 2 less then one from Oreilys.
Converted my rear brakes to disc this weekend. Seems like nothing ever goes like it should. Not enough hardware, should have checked that before I started the task then I didn't blow the crap out of the first caliper before I tried to pull fluid through , for me I guess this is what happens when being a shade tree mechanic...
What else is in that kit?
On the rear axel is there just one bearing per side and it is wide like the picture below? When I converted my drums to disks the right side looked a little on the dry side or lacking grease. Of course this was blocking my view of the lack there of, and of course this took me a few tries of putting the disc and hub on to see that it was holding me away from having proper placement of the caliper......... Anyway just one bearing per side?
How Many FT/Lbs to tighten axle nut on a 86 Brat??
Dinky26 replied to cole098's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've done the rear disc brake conversion on my Brat. Got the drivers side all set and good. Went to the passenger side, inadvertently left the cup over the bearing, put hub and disc on and finally realized what the deal was, pulled cup off finally got hub/disc lined up to get caliper on, tightened axel nut down and axel won't spin. So I Backed the nut off a little and axel will spin, axel seems tight and all without hub on. It did look like the bearing might have been a little dry. Does this sound as though I'm in need of a new bearing?..ugh if so how difficult are they to replace?? -
There was another member on here that pulled his needles off to paint them. I don't remember him having huge problems getting them dialed back in. Don't remember what thread that was though. Here is one thread that might help. http://www.ultimatesubaru.org/forum/topic/138292-how-do-you-remove-the-needles/?hl=gauges&do=findComment&comment=1163809
- 13 replies
UGH. ..... Just know your not alone on this John. :-(
- 13 replies
- 1
Awesome, if I were to have a kid you would be it SUBARU UP Nemi!!!
Good to know, thanks guys, like I've got some mucking around to do to get my gauges back to where they should be. Ugh...
- 13 replies
No problems here, just downloaded one to my phone, must be your computer.
Yes, I can benefit from any knowledge anybody has on this too. Maguires plastic polish eh, I'll have to get me some of that too.
- 13 replies
