jp98
About jp98
- Birthday 04/01/2000
Contact Methods
Website URL
http://
Gender
Male
Location
Gypsum, Co
Interests
What ever
Occupation
None
Ezboard Name
Referral
search engine
Biography
I'm great
Vehicles
98 Outback
Recent Profile Visitors
jp98's Achievements
Eat, Live, Breath Subaru (5/11)
35
If that 2500 lbs is what the trailer says it weights you better add another 1000 lbs to it after you fill it up with water, propane, food, gear, and what ever else you put into it. Those weights are dry weights before anything goes into them. It is best to load it down then go to a truck stop or somewhere that has a scale to see just how much they weigh.
No matter what kind of oil you are running get yourself a sample kit from Blackstone Labs or another company that will analyze it.. Get a sample and then send it into them. They will then send you a complete breakdown of what is in the oil and if you can go longer or if you need to change it more often.
I'd go somewhere else other than the dealer to have the charging system looked at even if you have to pay for the system check.. Even with short trips and a lot of starting the battery should be good enough to start your vehicle. If there would be a problem it should be the first start of the morning after the vehicle has sat all night and not when you are out on the road.
Oil and Filters?
jp98 replied to lmdew's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I have been using Blackstone Labs for all of my vehicles including a Ford diesel pickup. -
Oil and Filters?
The only way that I believe that you can figure out just how long the oil in the engine will last is to do a oil analysis on it. Find out what is going on with it and how quick it is breaking down. Going by charts and graphs along with oil companies and stories on the internet really don't tell you anything about how the oil in your engine is doing. All the oil companies are doing is telling you what they have found to be a average mileage. Not the low or even the high side of the mileage factor. Your engine might need to have the best oil out there changed sooner than the averages are telling them, but then again it might be able to run a few thousand more miles. You just need to get a analysis done to tell you -
Most home compressors are just 15amp 120 volt but there are 220 volt ones also. Get onto Tractors Supply web site and take a look at what they have to offer and see which one you prefer and then check it out to see if it will meet your needs. Don't forget hoses and fittings. For a hose I would go with a 3/8" one over a 1/4" one, the fittings are the same. Then take a look at the tools you will need to purchase. A air chuck at the very least. Then you will want to look at impact wrenches and ratchets to work on your vehicles.
Don't even try it by yourself unless you are experienced in doing it. Just think. You get the old one out and clean up all the old adhesive. Then as you and a buddy pick up the new glass and go to set it onto the frame it slips and cracks. Now you have to go buy another new piece of glass. It isn't worth it in my opinion. It is one thing that is best left to the pros.
