The relay is the ignition relay. The original (for 93 Legacy L AWD) is manufactured by JIDECO, part # 25229 AA001. Also has numbers RELAY 2M / MR5A414A1K12V / 20702M on it. Advance Auto carries this as GP Sorensen #41-5005 for only $15. HOWEVER, I just replaced mine today and no luck. Thus far, I have replaced the fuel filter, coil, plugs, wires, air filter, pcv valve, cleaned battery posts and connectors and now this ignition relay. Still no luck. Tank is about 3/4 full right now. I added some HEET, just in case moisture had accumulated. No luck there either. I'm thinking the O2 sensor is my next shot. Mine starts fine, runs good initially, gives you that warm fuzzy and then as you reach about 50 to 60 mph, it suddenly just lopes, pedal to the floor and she continues to drag, let off gas to pull over and she dies. Starts back up rough, idle drops very low, but works good enough to get back home as long as I keep the speed < 50 or so. I'll follow up when / if I fix it. Good luck.
