About Shep2112
- Birthday 11/12/1974
Contact Methods
AIM
754681
Location
Orlando
Vehicles
99 Outback Limited
Shep2112's Achievements
Advanced Member (3/11)
10
I got a 96 Legacy grill off eBay and it fit perfectly on my 99 Legacy Outback Limited.. The one difference is the badge is silver, where the Outback's Subaru badge was gold. Not sure if just on the Limited or all the Outbacks.. The little Outback logo just clips on (or off). I was able to move my Outback logo to the regular Legacy easily. On a related note, I'd like to find replacement grill snap-in clips for under the hood somewhere. They tend to get brittle and break over time. -Eric
Hey again, yup I try to get home a few times a year. We were just home for Christmas, so I'm not sure when I'll be home again. Yeah my family is all there, well, except my sister, who's in Mississippi. I drive a 99 Legacy Outback Limited wagon (30th anniversary, but mine didn't come with the sticker on the driver's side behind the front wheel like everyone else's 30th anniversary). It's been a great car for 7 1/2 years.. I've had a few problems here and there, but when it's running right, everything's great
Anyone from Georgia or the surrounding states?
Shep2112 replied to quazar's topic in Meet n' Greet. Your USMB Welcome Center
This sounds like a really nice place (and it's MUCH closer to Orlando http://www.fs.fed.us/r8/florida/recreation/index_apa.shtml Will there be an option to move in if we really like it? We're in the market for a house anyway -
Hmm, perhaps it's that, but I'm pretty sure it's from the solenoid. I called a Subie specialist back home and he said he hadn't heard of a sound like that before. He thinks perhaps my LoJack installed alarm ($600!) is causing this problem and thinks I should have it bypassed by someone to see if things are better from that. Another guy suggested today I get the starter rebuilt, said there's a place in town that does rebuilds for like $65.. Does this seem like a viable option? The 2 dealers nearby want $230 and $250 for rebuilt OEM starters. This more than double the prices I found online, but I don't know who I can trust online. The AutoZone Duralast starters have a lifetime warranty I was told, but are these any good? I'd rather not have to USE a warranty.. (insert wallet here)
Okay thanks. I'm gonna pull the assembly out today or tonight if I get a chance, otherwise it will have to wait a few days But does anyone else Subie have a solenoid clicking sound when the key is ON? Mine has done that since I got it new and I don't know if this is normal or not? I believe it's caused by the 5 volts being sent to it, but either way, SHOULD it be doing this? I just want to know if there's something else going on here or if this is a 'feature' Thanks! -Eric
You're from Dalton too? Small world Finally got a bit of snow I heard.. Are you getting the work done at Pete's? They do good work there, but they charge for not doing stuff. I brought my Outback there a couple years ago to have them check something to see if it was under warranty. They told me they had to check out the problem first and then check the listing of what was covered. And charged me $65 because it wasn't covered. They claimed they couldn't check the list without checking the car.. Pretty lame :-\ -Eric
I know, just wanna make sure I don't kill any replacement parts. :cool: So where is the 5 volt leak coming from, and does your Outback click when you switch the key to ON? Mine always has, since day 1, and when my engine was rebuilt/replaced/whatever, they didn't fix it. So presumably this is normal behavior.. But the flickering light.. What is that all about? On my trip back to Florida, both times when it didn't start, the AT light was flickering just like this. So I'm fairly certain something is wrong somewhere. But it does spit out 12 volts to the starter even with the flicker.. I'm just trying to be cautious.. What's a decent price for a rebuilt starter/solenoid? Are there any aftermarket units I could get through a chain store that would be reliable? Thanks Eric
Alrighty.. So then would the starter/solenoid be possibly good then? Even though connecting the control cable of it directly to the battery still produces a clicking too? What should I pull out? The transparent topped fuses look good in the fuse holder under the hood. I believe all of the fuses in the fuse panel under the dash are good. I've pulled the cluster a few times to replace the bulbs with others, and then replaced them again with LEDs. I made sure everything snapped in when I reattached it but I can check that again. I didn't retest the battery terminal voltage. It should be close to 12.4 or 12.5 still though. The windows move just fine. I mention this because when I was watching the 5 volts on the starter control wire when the key was ON, it was dropping down by .01 volts roughly every second. Starting around 4.98, I watched it drop to about 4.87 volts. It was a consistent drain. I don't know if it was dropping from the battery, or just draining from something else. Not sure if this indicates anything. Another thing, when I was touching my wire from the starter directly to the battery, there was no spark when I connected it, but there was a sizable spark when I pulled it away from the positive terminal. Maybe an inch across or something. ahhhhhhhh this is no fun..
Yeah I know. This would be so much easier to find someone local and figure this out over a pizza or something.. I attached a video clip of me trying to start it just now. There's really nothing visible under the hood, just the same sound, but louder. You can see the dash lights fairly well in this. In Windows Media Player, pressing Alt-3 will zoom to 200%. You can clearly see the AT Oil Light doesn't flicker before the first start attempt, and then flickers after that. That's gotta indicate *something*.. I can pull the cluster and check the harnesses tomorrow I guess. outback.zip
Exactly. I don't think it's supposed to have 5 volts shooting at it non-stop. Does your car have a clicking sound in the ON position? I never understood it, just assumed it was 'a Subaru thing', though I couldn't think of a reason why anything should be making noise when the fan switch is on '0', etc. Would resetting my CEL several times with the engine running cause any adverse effects? I'm really at a loss for what to do next :-\
Thanks Nipper, My ABS light came on briefly the other night when I was driving on the defective battery to swap it at the store. That was when I hit the brake pedal. So electricity can do weird things, yes. But what should I do about this? If the starter isn't connected and the light comes on, is that indicating my starter is not being 'seen' and it's letting me know, or is there something wrong with something else that I need to check? :-\
I can check with the usual chain parts stores (Autozone, Advance Discount, NAPA, etc) around here. It's not flashing 16 times though, it's flickering continually. And just the AT Oil Temp light is flickering, not the whole dash (I think I may have stated that incorrectly in my original post) Since it doesn't turn, just clicks, when I attach that directly to the battery, I think it's safe to assume the solenoid/starter is bad. The light flickers even when the solenoid is not attached to the key switch. But why is the light flickering? Does it flicker when the solenoid isn't attached/is malfunctioning as a notification? Why is there 5 volts heading to the solenoid whenever the key is in the ON position? Do all Subies click when switched to ON and all of them spit out 5 volts continually into the solenoid? This seems strange to me. I'll check around for rebuilt starter assemblies, but I'm afraid if I don't correct the flickering AT Oil Temp light problem, then when I attach another one, it's going to damage that one too.
