idosubaru
    344
  1. It’s piston slap. It’s benign and unfortunately no easy solution. headgaskets or major work, is a good time to consider having the pistons knurled or new Subaru block installed to address it
  2. It’ll still be there when you and I are gone too. His are out of earths orbit or old ones in orbit gradually descend and fall to earth in 200 or 2000 years, they don’t get deorbited like modern satellites!
  3. Best oil decision is to check it often. An average daily driver will have oil related issues due to low oil, not brand. If you really want to know send samples to oil labs and get it checked they’ll tell you how long your interval should be for that vehicle and if there’s anything problematic with your oil choice Run oil not additives. Use Amsoil Or anything else - there is zero data that lightly used vehicles are dropping dead because one ran Castol instead of valvoline. synthetic is superior but if you’re going to change it often anyway or it’s an older vehicle that uses some oil then it’s pointless or not a good fit.
  4. 225/60/16's run perfectly fine on my 2009 legacy with no rubbing. But they are very very tight with small wheel well margins. Snow will pack and freeze in the wheel well and rub and is harder to get off with such small clearances. Those are the same width and 2.5mm shorter than the tires you want to install. But you're installing them on an Outback so you should have plenty of room for that extra 2.5mm. (0.1") Use the following and click "comparison" to see dimensional comparisons of two different tires: https://tiresize.com/calculator/
  5. Good job narrowing it down to #2 cylinder. Coil seems likely candidate to check and it failed right? Failed injector or ECU seem unlikely given those symptoms.
  6. What’s this data and due diligence? You’re supposed to say “my car shifted funny should I replace the coil? Youre sure it’s a phase II 99 EJ22 and the proper FSM numbers? 99 is an odd year for EJ engines. They have both earlier EJ and later EJ characteristics Did you have a code or codes? Is there a reason you’re not confident the failed test means it’s bad?
  7. You probably already do this but - use excellent quality 6 point sockets. No 12's. Use the combination of socket/adapter/reducers necessary to get a 100% perpendicular seat on the bolt and torque on the socket handle. It's fairly easy to get "close" on these, when actually it's at a slight angle because the socket or extension is too thick and doesn't have clearance in those pass through ports. Such a silly design. But I've done it before - had them rock/wobble/slide off because they're not perfectly seated. I hate them too but haven't had any 05-09 rear caliper bracket bolts not come out yet. A little valve compound in your socket adds grip and can mitigate small clearance issues due to rust/wear between the socket and bolt head. Unlikely to help in this case but if you've already got some laying around....?
  8. Ha! I thought so. That’s great. That was me, though I changed my username since then so it may be less recognizable. Some auto parts stores will rent for free or loan tools out and may have it if you want to DIY. That kit is too awkward and heavy to pack and ship and then ship back for a one time use or Id suggest you borrow mine.
  9. A new cam, new cam seal, and it still leaks from the ID of the seal? Wow. I'd wonder if the cam carrier is allowing the cam to walk or is otherwise distorted? Cam carrier/head may need replaced?
  10. Good job catching that pan/solenoid, I've seen a few of those solenoid connectors broken before for the same reason.
  11. EA82, RX, XT6 - all of them will work, they all interchange the same as far as bolting to an EJ22. So you're good to go.
  12. looks like a good try, looks like standard aquarium hose available at wal mart or other places so when it dries out/cracks should be easy to swap out. Proprietary hoses are annoying. If it's relatively easy I'd clean it afterwards and store it out of sunlight and wrapped up to prevent UV/O2 exposure, I wouldn't expect great longevity from that. I've been around a reasonable amount of fluid pumps and small cheap hobbyist ones are prone to fail. A local large land scaping company quotes new pumps for many jobs and throws them away. It's not worth their time to maintain/expect them to work because they have so many issues with them. harbor freight has a few options but none look compelling over that one you posted.
  13. It sounds hosed. But I agree that is interesting for it to go downhill the way you described. I assume the pan isn't damaged/dented right? The ATF pick up is insanely close to the pan, denting in the wrong spot can inhibit fluid uptake. Ideally this would have been attempted when it was still drivable but disconnect the TCU entirely - does it drive then? It'll run in purely mechanical mode - no torque converter lock up, no shiftings, 4WD is "locked", permanent 3rd gear no matter what gear the shifter is placed in. But it'll run and drive fine as a test. If some symptoms go away or get worse it might tell you something. And it renders the vehicle usable/movable which is helpful. I drove an unwworthy to repair rust bucket subaru 4EAT many years ago for a year like that. Do you mean ATF and do you mean this vehicle? If not: I'm assuming you meant you've changed the ATF in this car but just in case - a wild theory would be - Maybe the fluid you drained was loaded with trans x and it needs to drink more of it to function?
  14. Have you tried lessening it to like 40? Can you experiment until you find the maximum pressure they'll take without tripping the light? I'd just guess it's around 40 psi. When you find that maximum it will probably also give you nearly identical gas mileage as 50 psi...all things being equal (which they won't be with changing seasons. 50 is probably "maximum", not a recommended pressure. Tire manufacturers don't give recommended pressures because they don't know the final application/vehicle it'll be installed on.
  15. Yes need a hub tamer. Oddly - didn’t I buy a hub tamer from you like 5-10 years ago?! I thought you used to have one? You can use a press but carefully. Id get Subaru bearings and wheel seals or score a used knuckle. Order a nice clean rust free used one from south or west.
  16. How confident are you/him this is an axle noise? Maybe it's the CVT making the noise? Let's assume his diagnosis is correct for a moment: Excellent. A dipstick check isn't very conclusive or condemning. Change the fluid, have the fluid dumped into a clean container and inspect the fluid. Blackstone labs I think can test the particulate matter of CVT fluid and tell you what it is and whether it's more indicative of wear or worse issues. If the noise is an axle and there's no transmission noises then there's a reasonable chance of not having any issues either. CVT's aren't very good at failing quietly. You didn't ask but do not use any parts store axles. They all suck no matter what rando review you read on line. You will not find the holy grail you, or others, think exist. They all suck. Regrease/reboot your original, or install a rebooted/regreased used Subaru axle. Aftermarkets are total trash. All of them. Unless you like gambling with insanely high failure rates and wasting your time swapping axles multiple times. Install a Subaru axle or reboot/regrease the original. They typically last the life of the car. The ones I've regreased/rebooted the old grease just pours out and is absolultely trashy...or it's mostly empty/dry. I've never rebooted a noisy/clicking Subaru OEM axle that didn't drive like new afterwards. I of course avoid ones that have eggregious issues, I don't blindly regrease ones filled with sand (which I've seen before)
  17. car-part.com for used trans pricing and availability. 2013-2017 Outback CVTs are interchangeable even though that database says they are not. I’ve never checked into 2011 comparability but you might have more options than it lists. He’s wise for installing new - saves him and you the headache of used parts issues. And Any aftermarket rebuilt AT for Subarus should be avoided. The glaring omission here is why was he looking and how did he check? ”presumably” - does this mean you just got the car? If so, there’s a good chance you just bought someone else’s problem after they got the same quote and sold it to you. I see this happen all the time. Enough of that Sherlock Holmes talk - back to the omissions: If he checked via the dipstick I wouldn’t consider that a reliable diagnosis. Drain the fluid and check. If it was drained, why was it drained? Or did you have symptoms that promoted looking for issues? Transmissions can have debris in them - the magnetic rings always have built up debris on them over time in the pans. So you’ll need to describe this “shavings”. But yes - “shavings”, in the way I’d use that word is absolutely catastrophic for an AT. That said - I could envision plenty of scenarios where I’d fill it with new fluid and see what happens. As annoying as those are to fill. 2017 CVTs work in 2013s, not sure if they go back to 2011 but that might expand your used options if you need that route
  18. How much/how quickly is it leaking, is it external or internal leak, is it the original gaskets? If it's a slow, external leak, on the original gaskets then you have a really good chance of it working. I wouldn't try if you suspect a reasonable amount of internal leakage. If it's leaking a lot or the gaskets were previously replaced - chances aren't great. If it's an internal leak - it has zero chance of working. This is when I think it can cause problems. This might not be 100% accurate but for example - Normally coolant conditioner is suspended in solution and doesn't "react" until it's exposed to a leak. So it doesn't do anything to cause issues. In an improperly working cooling system the conditioner may be exposed to air pockets, exhaust gases, pressure/temp fluctuations that may encourage it to react internally where it's not suppose to. This may or may not matter or it might take more than one bottle to cause issues, I haven't tried that enough to say. But I'd probably try to diagnose how much/how quickly it's leaking and if it's internal or external before attempting it.
  19. Stateside they're in the $50's from Subaru, that's where I get them. I think they were $40 last time I did it.
  20. Hmm there is that. We have all be there before! not wanting to make it worse or ruin a chance of it being flaky enough to work right again.
  21. Any uncertainty on how long it ran hot, or if turn around time is critical: JDM. If turn around time isn’t critical, or it overheated on someone’s watch that I know: repairing is a reasonable option.
  22. interesting feedback. someone posted earlier about repairing the sensor does that look doable? Do the testing instructions give clues to how to bypass it? GD mentioned ohms… As already stated removing the entire seat is 4 bolts and disconnect the plugs. They drive fine without the seat, ive driven subarus without any front seats at all LOL. So you could remove the passengers seat for testing purposes and still use the vehicle. A second person might help keep the lower metal tabs of the seat from scratching anything inside or outside. They are awkward to wiggle out. But I’ve done gobs by myself and it only takes a few minutes.
  23. Buy a used lower cushion and swap it out. I have one but it’s not worth shipping or rendering my parts car without a seat. Good call - you should be able to mimmick the sensor to always be “on” rather than “off”. I don’t know the functioning of the sensor to say how to do it though. But it’s probably a simple toggle mechanism or limit switch somewhere just on/off. there’s no circuits, ICs, or code embedded in the seat. This sounds like a great solution Im not sure why this feature exists, maybe it’s so the bag doesn’t go off with a short person or pet in the seat who might get injured worse by the bag? But that doesn’t seem likely since it doesn’t take much to trip it and a pet can’t be restrained by seat belts. Or maybe it’s to avoid the passengers side airbag blowing? I just rebuilt a totaled 2017 ans every single bag in the car went off except the passengers side airbag. Even the drivers wheel and passengers side curtain and passengers seat went off but not the passengers bag. That replacement block scenario is bizarre. I don’t know why that’s been so complicated but it seems like it’s gotta be something beyond Subaru Corp going on behind the scenes.
