idosubaru
337
Yes CVT only. Make sure all the recalls are done when you get one. You can add a Subaru extended warranty to any Subaru still under the factory warranty. I’m just not sure if a second owner can if you buy it used. If you can do that as a second owner, another option is to buy one still under original factory warranty and add the extended Subaru warranty. It used to be relatively inexpensive for 100k or even 120k warranty so it was a great deal for some folks. Subaru did I think start limiting dealers from selling the warranty for cars not sold at their dealer. You used to be able to buy the car in New York then call a dealer in Texas to add the warranty. I don’t think you can do that now and so your pricing may be worse or depending on local dealer. It is negotiable in price though so you can google what others have paid.
something is seriously messed up in that picture. The toothed pulley is not next to the cam sprocket. there’s a smooth pulley next to each cam, there shouldn’t be a toothed cogged idler all the way up there. I’m guessing it totally disintegrated or sheared the bolt off and jumped up that high. That’s the one most likely to fail by 100 miles.
No. If you’ve gotta be cheap get a Subaru belt and lower cogged pulley. You can even leave the covers off to monitor the condition of the other pulleys. The others fail less often and the belt can slide over them instead of everything turning to $!&’jnj!$&! immediately if it fails. The pulleys will rust if it sees a lot of winter snow treatment. Still can run it as the riding and contact surfaces stay clean but it does rust If you get an aftermarket kit don’t use the included bolt, they’re substandard low grade metal and I’ve seen them shear within months of installation (not installed by me) No point replacing the pump. Those EJ pumps fail so rarely you have far more chance of your new aftermarket parts failing than an old pump if it’s OEM. At most maybe it leaks later but probably not. I’ve never seen a failed OEM EJ water pump. Other Subaru water pumps I would replace proactively but not cost conscious EJ jobs.
Awesome. Thanks Chux, very much appreciated. 2016 is the year I’m currently thinking about so I might buy that same alt you looked up If I can’t find a low mileage used OEM. Currently 200,000 miles started life as a southern car, zero rust, in impeccable condition so there’s a decent chance of a lot more miles so I’ll likely replace the alt preemptively.
(Ignoring 00-04 fuel pump cap tab cracking and oring issues). I’d guess alternator but have never kept track. Alternator sees more heat cycling, isn’t sitting in a “cooling fluid” (a tank of gas like a fuel pump), and it has more of a “computer” with the built in voltage regulator. I’ll ask my parts guy how many alternators vs fuel pumps are in the regional warehouse for fun.
Subaru only on wheel bearings and use a torque wrench that’s accurate. Or the OEM supplier if you can verify it. Sometimes you get an OEM bearing in a MOOG or Beck Arnley Box then the next time you buy the same bearing, same car, same supplier you get a non-Subaru bearing? Moving target unless you can verify the manufacturer. Non-Subaru Aftermarket wheel bearings are trash and fail all the time. They fail less often if torqued very carefully, use a toque wrench. Follow the Subaru manual procedure. Torque before putting the car on the ground. I can zip on Subaru bearings without a torque wrench and they never fail. The aftermarket bearings needing much more babied gives me littlr confidence in the long run so I avoid them when I can If you’re having repeat failures using OEM Subaru bearings and proper torque settings then let us know: 1. Has it had an alignment? 2. Do you have records of how many times and mileage you’ve replace each rear bearing? Post it if you do 3. have you owned it since new? 4. has it ever been wrecked? 5. Is it rusty?
Manufacturer or pattern difference doesn’t matter. It’s size dependent. It’s like driving a Subaru or truck on pavement with locked 4WD, which binds when turning. Different size tires can cause the same exact issue by virtue of tire circumference difference rather than turning radius difference. Subaru lists their recommendations looks like others have posted that If it’s a VDC or has a VTD, they’re indestructible in regards to the rear transfer gear set. Run 4 dramatically different tires and you won’t blow that thing up. Im joking but I don’t care to run a mismatched tire on VTD, it doesn’t matter. From a physics stand point running one new tire on a Subaru isn’t a big deal if you pay attention to your diffs. But that’s too technical for public consumption. On MPT transmissions with open front and rear diffs, If buying one new tire - place it where your tires wear the most (front or back). Rotate the older three tires until the new one wears down to the same tread depth and then they’re all the same. The smaller tire diameters will be the “driven” tires since power goes to the one needing less torque. From an engineering stand point the larger tire won’t be the one the differential “sees”. There are tire shops that will install two new tires - one on the front and one on the rear opposite side of Subarus for these same reasons. I never figured out why they do opposite sides except maybe just for traction on both sides of the car for rain/snow. if you have rear vlsd they usually fail and operate as an open anyway. Lol. But if one cares, put the larger one up front which is usually seeing more wear on older Subarus. If it doesn’t then you’ll have the unfortunate situation of the smaller tires wear outpacing the new larger one. Now if the three wear down you’ll be be stuck with one smaller tire and potentially 3 new tires which is a trickier situation to juggle regarding “mismatched tires”. If you have more than 4 tires just rotate them accordingly until they all match.
It can work if you make it work, we've already given you what you need to know to do it. Make sure the final drives match. Swap the rear diff to match, that donor trans is 4.11 and outback is 4.44. Get the flex plate if you can...it's been awhile but I think all the 90's flex plates interchange just fine, but I'd just get it, there's no reason not to.
I wouldn’t leave a 20 year old belt on an interference engine. If you’re positive it’s Subaru it’s got a lot better chance than aftermarket I’ve seen clutches free up on older ones that sat, just by driving. I’d drive it and periodically remove the FWD fuse to see if they’re any better. Initial torque bind almost always responds well to fluid changes so that’s worth a try IMO.
1. Check the pad clips. They may be bent or have rust on the caliper which pushes the clips out a little. I’ll remove clips and make sure no rust is bubbling under them on the caliper bracket. 2. hose collapse. If a flexible rubber hose collapses internally it’ll prevent the fluid pressure from backing up and the caliper can’t release fully. The brake booster provides enough pressure to push through it. It’s not very common on Subarus. I highly doubt it’s the master cylinder.
local shop here charges $50-$75 to weld a rusted flange or joint. I’ll toss them a $100, that’s too cheap. I’ve installed a couple of low cost eBay or rock auto exhaust parts. They bolted right up and work if that’s all you’re asking for. They will rust a lot quicker than stock OEM if you’re in the rust belt or want them to last 10+ years. If you plan on owning it a long time I’d look at it carefully and if there’s any signs of other rust or rusty flanges/muffler it’s worth just replacing it all now.
Intake hose. Air cleaner hose. Valve. Solenoid. Intake solenoid. The EJ18 has some wildly confusing intake contraptions. The blow out on the intake hose you posted looks too big for a small solenoid hose - it’s more like egr Recirc size. But the broken solenoid is definitely a solenoid. Subaru online parts diagrams are fairly decent. I’d look those up for part names and number. Then search google or eBay or junk yards using those names and numbers. This is just an example and not necessarily what you need but first thing I pulled up for example of a 1993 intake hose diagram this may include the valve or solenoid you need: https://parts.wheelingsubaru.com/showAssembly.aspx?ukey_product=49227167&ukey_assembly=6021290 https://parts.wheelingsubaru.com/showAssembly.aspx?ukey_product=49287214&ukey_assembly=6021122
Turn very sharply on sweeping turns at 40+ mph both to the left and right. If noise goes away under that side loading it’s the bearing. Not just during the sweeping turn. But even do a quick 1 second extra few degree turn while doing the sweeping turn to the right or left while turning. Noise will disappear during that momentary sharp turn at speed. This is the most consistent test I’ve seen on ones that are relatively loud. havw someone else drive and sit in the rear seat or hatch area and front passenger seat it should be obvious which corner it is An infrared temp gun on each rotor will tell you if one is much hotter than the other side. Take lots of readings at same point on rotor as the heat dissipation and readings aren’t consistent. But you’ll see a pattern and 30-100 degree difference. This doesn’t always work either but catches some that pass the “play” and typical bearing tests Moog bearing has a very good chance of failing again. I avoid aftermarket bearings and I’ve still seen numerous failures. Moog, Timken…even the “good” ones you just never know. I’ve never seen an OEM Subaru bearing repeat failure. And I use them far more often and on any car that’s likely to see a lot more years/miles If you use after market bearings they have a lower failure rate if properly torqued. The Subaru bearings can be zipped on and abused with an air gun and not torqued and walked in back forth to a rusty hub and never fail. I don’t use a torque wrench on Subaru bearings. Not one failure. Aftermarket will fail if they’re treated roughly, not installed straight and torqued properly. Which speaks to their quality and all the more reason to avoid. But they are cheap so if you use aftermarket again clean everything up, install it straight and clean and torque it properly.
Well shoot, I'm unsure about the SVX The SVX has a rear LSD, I wonder if those axles are different. My guess is you swap the rear diff guts. Which isn't hard nor does it take long...but I've never done it with an SVX so I'm unsure on what can be done or best approach. Here is what you need to end up with from swapping the guts between the two differentials: 1. The ring and pinion from the forester (for the proper 4.44 gear ratio to match the transmission) 2. the rear diff chunk from the LSD (because it'll properly receive your axles). I'm just not sure which housing to use, either: A. install the Forester ring and pinion into the SVX housing. The pinion bolts to the housing and the ring bolts to the (SVX) diff chunk. In this case you'd want new pinion seals and side seals. or B. install the SVX guts into the forester housing with it's original Forester ring and pinion. If you do this - you keep all the side caps, shims, everything identical in the SVX and swap them to the forester. In this case you'd want new side seals. B would be easier because you don't have to mess with the pinion which is kind of beastly and then you probably need to replace the pinion seal and maybe that messes with preload on the R&P? It might be better to keep the R&P within it's own housing....just a wild guess but that's also what I've always done. The non-LSD housings (the forester) have little bumps inside you grind down so the larger SVX LSD chunk can clear the housing. It's not as hard as it sounds. Try to install the LSD chunk and you'll see it hits the bumps inside. Knock that down with a grinder until the LSD fits. It's not much and doesn't take long. Another option might be some kind of axle swap or frankenstein axle, but I'm unsure if that's even possible. I've done these types of rear diff gut swaps to change gear ratios or swap LSD chunks, but I've never done it with an SVX or due to axle problems, so that's why I'm unsure.
hold onto the bad trans until you know the donor trans pan isn’t dented and it doesn’t have toque bind. And it’s not missing the torque converter, stubby shafts, or shift switch on the passengers side. Usualky they just come with all that stuff but I’ve seen all of those missing or damaged before too. but in general, Nope. They’re basically the same trans with slightly different guts inside and all that stuff usually stays with the trans Torque bind isn’t uncommon so if you wanted you could save the rear extension housing (it’s like 6 or 8 easy bolts and it pops right off). It has the 4WD clutches and solenoid. Or just hold onto the trans At least until you drive it and verify the donor trans doesn’t have torque bind. Then throw it away or keep the rear housing if you have room. make sure he knows how to properly seat the torque converter, if you don’t the oil pump will crack inside the trans. The torque converter and flex plate should not touch when the trans is bolted up to the engine and installed. The flex plate bolts will draw them together.
-50F haha, wow. The first question is - There’s lots of Subarus in Alaska I doubt they’re all replacing boots annually. Maybe they’re coastal and more moderated temps? I’d upgrade to OEM 00-04 OBW axles and new Subaru boots. No need to reinvent the wheel if those work. You can feel a difference between the 00-04 outer boots and 90s boots as soon as you remove them from the box. The material is way different and very robust. If yours is lifted,colder, both, or otherwise stressing the boots more than other Alaskans, I’ve seen a company years ago that made silicone boots from dimensions you send them. Don’t recall the name. The linked heavy duty axle is not a good axle. Might get lucky but They aren’t the first company that tried to sell a Subaru axle marketed like this and they won’t be the last.
