idosubaru
337
Yeah it’s been awhile but 99 Outback/Legacy SUS is odd. The 95-99 Outback legacy engines all swap. so it’s hard to imagine the trans doesn’t swap. But - I think those 99s have the Phase II trans. If the trans has a spin on filter then it’s phase II. 95-98 didn’t have that. also 95-99 all EJ25s swap except the 99 Forester and Impreza RS. And all 95-98 EJ22s swap electotncialky but the 99 EJ22 doesn’t for any of them even though the 99 EJ25 does swap with esrkier models for legacy/Outback. Just the 2.2 doesn’t in 99. thoroughly confusing year.
Subaru OEM boots? They’re way better than standard aftermarket. They don’t break in a year. I reboot my Subarus when I get them and never have to do it again even after 100,000 miles. That never happens with aftermarket. if you’re using 90s axles upgrade to 00-04 Outback style axles. the boot material is better, particularly the outer boot, it’s “stiffer” and the outer boot has more convolutions. They have the tone ring on them, just tap it off with a hammer it just sits on the ridge. They can even be left on but I remove them. They’re a direct swap into 90s EJ vehicles. I’ve seen silicon boots for sale but I forget where. Google should find some.
Piston rings. Not ideal to have another shop do it for a litany of reasons. Unless they’re very experienced in Subarus subaru doesn’t even fix it, they just replace the entire short block $2000 new block and $3,000 for new headgasket and reassembly. Costly but at least you get a good warranty out of the new block instead of just 12,000 miles and 1 year from a typical shop repair the good news is they come with a 36 month unlimited mile warranty. Used to be 36,000 miles now I think it’s just 3 years no mileage limit. That’s just the block, everything else, which practically speaking is just the headgaskets, would have the standard 1 year 12,000 mile warranty Best fit solution: schedule a reasonable check and top off schedule you do routinely, don’t keep using the dash light. Top it off every Sunday or night you’re home or gas fill up, I see people checking oil at gas stations (I travel a lot), you’re already waiting for the pump anyway. When you change the oil, overfill it a 1/2 quart. The top fill line is extremely forgiving - if it wasn’t then every mountain, curve, steep boat ramp, hard braking causing the oil to rise on one side or slosh around would damage the engine. Pro tip: none of those damage the engine. Use thicker 40weight oil. 10w40. Shoot as a test I’d run 20w-50 and see what happens. But that freaks out the inexperienced oil nazis. Either way - don’t use the recommended 0W-20 garbage
Check wiring for rodent or prior engine work damage - just the exposed, easily visible wiring, that's what they'd typically find first as well. Follow the wire back from the solenoid as far as you can. Are you sure you're addressing the correct side, there's two right? Make sure you're looking at the right one.
I’ve rebuilt a ton of totaled cars which many people claim is hard, terrible, and fraught with danger and potential rejection or unknown problems and the state is out to get you. I’m an untrained DIY guy, never had shop classes or been in auto business. Never had a problem rebuilding a totaled car and getting a real title for it. It’s not a big deal. I haven’t done a title-less car but after the rebuilding process I wouldn’t be deterred if the right situation presented itself. I’ve seen the process listed looking at potential buys and other car protocols. The state tells you what to do - go do what they say. In my experience the inspectors and people involved aren’t as bad to deal with as many claim. They just want to see the I’s crossed and T’s dotted and nothing sketchy and you’re good.
Nice work Brucey. That's cool trying things. Keep it up. The guys at Hartsells on University got a kick out of inspecting the legacy I converted to FWD automatic just to do it. You did the hard work but hindsight being 20/20 It seems risky to have an unforgiving data point downstream of the final drive output. I've got a 14 Forester parts car I was wondering if I could swap the trans into an outback....looks like it would work on what you're doing. I ran into a police officer at the local highschool a week or two ago and he said "Dude I saw an XT6 just like yours, look at this picture".....it was mine. Lol.
Would 5w-20 oil be good for my 1986 gl wagon?
idosubaru replied to Dumpy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
run whatever you want, they're dead men walking anyway? and hey I get it, it's not like it's easier to daily drive my XT6 than our 2016 outback. -
Is it covered under your insurance policy? That's in a very bad area and good chance it's causing the codes. Splice the broken wires to repair or replace the entire harness, Subaru will have those in stock (i think). Subaru will only replace the entire wiring harness, they will not repair the current harness. At least all the dealers I know won't, maybe there's a few willing to "break the rules".
Taking it apart - can you check continuity from the connector wiring harness side to a point on the circuit board of each pin as far down stream of the connector as possible. maybe also why wiggling or pressing it to the side so to speak. If you have access to any used Subaru parts All 1995-1998 4 cylinder 2.2 liter and 2.5 liter, Outback legacy Forster Impreza TCUs all readily swap.And 99 Outback’s and Legacys. I think even a FEd TCU is plug and play lol
Read the owners manual. You can run any reasonable oil. It would be fine. I’d probably avoid 5W on EA engines but for no reason. For what it’s worth GDs shop superior in Portland runs 5w-40 synthetic as a rather standard oil for various non turbo applications, I think including EA engines. Of course hotter temps will be less ideal for thinner oils and that’s a good reason to check the manual like prior post mentions. -
Are there any engine codes (check engine light)? Not saying this to be mean but for clarity: running well isn’t important - are there any check engine engine lights or codes? Check if the ATF pan is dented. It can cause problems much easier than a dented engine oil pan. You can attempt to extract the AT codes: some newer Subarus like 2005 ish I think but I forget the years, I have a very easy way to read the codes without any scanner. Not sure it applies to 2002 or the classic schizophrenic multiple personality disorder meth smoking strategy Subaru employed here which you can do yourself with no scanner:
