7
Everything posted by ShawnW
EVERYONE: Please be sure to use the feedback system on USMB. Alot of this could have been avoided. John isn't perfect but hes providing a service that no business would be able to properly provide services for so I think we should cut him some slack but if you disagree, or it takes an unexcusable amount of time you are more than able to leave him (or anyone) a negative feedback. Please also be sure to not duplicate postings in an attempt to "get your point across". Thanks, Shawn Former ASSISTANT ADMIN, back when there was a BillyC on USMB.
Shape Doesnt matter, almost any of them are very user friendly on the instructions too.
Flush with the block and no further. Tap it in with a rubber mallet.
custom axle info and identity help
ShawnW replied to wounded brat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ill sell you my custom axles with 0 miles on them but they have been installed. I paid $120 a piece for em i want 100 each for em and you can keep your cores I won't need em. Im going to rebuild my transmission and switch the stubs out so I can run standard axles. These were built by CV Of Ocala. -
COPPER HEAD GASKETS for XT6!!!!
ShawnW replied to Gravityman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
How much boost do you really need with twin turbo xt6? Seems like a stock 7PSI would be unbelievable as is to me. -
Congrats to Mick (McBrat) for getting a full page picture of his Brat flinging mud on page 3! Theres a pretty damn happy passenger aboard too.
AIS and reed valves, Q's an need A's Please
ShawnW replied to a topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes, they have em on the Carb'd engines and usually 2 on the ea82's. -
Compression tester into #1. Turn engine by hand until compression rises and then watch the flywheel for the 0 mark.
Just to help you not repeat your mistake. Cam gears have arrows on them. Make sure they point at 2:00 and the notch in the side of the gear is at 12:00. The solid lines on the new timing belt (USE A NEW ONE!), line up on the 12:00 marks. The crank gear has a notch for 12:00, make sure thats pointed at 12 and that another mark at 3:00 is pointed at 3, dont make it so you have 9 and 12 on the crank. The Key for the crank pulley should be at the bottom if you have it right. Also be sure you dont follow the manual on the crank pulley bolt torque. Books say around 80 pounds, it should be around 120. A healthy 1/2" impact gun will torque it properly. Use Locktite on the bolt. If your belt tensioner looks like a long tube with two bolt on ears, you can re-compress it in a Vise. If it doesnt, then either get a new one (recommended) or take it to a Subaru dealer to have them re-compress it for you.
99 cd player
ShawnW replied to elviscan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Marketplace is a good place to start for just the CD section if its the 2 din separate radio that has am/FM/Cass on top and CD on bottom, etc. Ebay has always been good for the 6 disc in dash takeout units from WRX's and such. These look and sound awesome! -
rocker panels/fuel tank
ShawnW replied to 20 buck brat's topic in Old Gen.: 80's GL/DL/XT/Loyales...
A 80-84 4wd wagon or coupe tank will work in an 82-88 Brat as well, dont rule those out. Hatch won't work. -
Door Chime
ShawnW replied to Reverendray's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Does your dome light flicker on when the key chime comes on? If so the door switch is bad. Attack the cause of the problem instead of the result. -
Drill Bits for Hardend Steel Bolts?
ShawnW replied to MorganM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
COULDNT AGREE MORE! -
How to crosshatch a cylinder bore?
ShawnW replied to Subarutex's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Really shouldnt be doing anything to the cyl walls now that the pistons are installed unless you want to take em back out. The grit created would cancel out any productive gain you do to them and hopefully the pistons are sized to the block properly and enlarging anymore wouldn't be good either.
