6
Everything posted by ShawnW
I did a search and got this result: Oil Pan Crossmember
Will the "high" middle console fit in my 84 wagon?
ShawnW replied to lastchance's topic in Old Gen.: 80's GL/DL/XT/Loyales...
When you find one make sure you get the bracket under the storage compartment that it screws down with. Your current one would be too short. I got around that with my old hatch by getting a really long screw but it wasnt as nice. The grey one I sold on ebay was rare cuz it was from a Brat without power windows and the plastic blank was still in. -
Broken front axle.
New 1st gen owner.. knows nothing
ShawnW replied to RavenTBK's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thats your front differential dipstick tube. It should have a stiff dipstick in it. -
A volt meter or test light will do wonders for figuring this out. For a stereo install you usually have to find ground, constant power and switched power. Constant power comes from the circuit that the hazards, horn and clock for example run on. So with the key in the off position dig around in the radio harness looking for a wire that has juice....and then switch the key on and look for one that has juice when the car is on. See? Once you have juice then you figure out what pair of wires goes to what speakers. I highly recommend running new wires to the speakers and leaving the existing speakers and wiring intact if possible. Then when you move onto the next car you are able to take your goodies with you if you want.
Chrome bumper rust question????
ShawnW replied to biffanyus's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Polish or rubbing compound usually. Something with just the slightest grit, rinse it off and then wax the surface?? -
Need some speed@rpm numbers
ShawnW replied to TROGDOR!'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
Do u have access to a GPS? -
Mystery of the Heat Gauge????
ShawnW replied to mkarns's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Is the radiator original to the car? Most of the guys with 80's Subaru's on here have replaced theirs in the last 2-3 years...age really seems to be catching up with the radiators lately. Your radiator cap might be bad and not holding pressure. -
NEED HELP..... momo adaptors+info for tex
ShawnW replied to subaru_styles's topic in Old Gen.: 80's GL/DL/XT/Loyales...
GD do you want old steering wheels to make the adaptors out of? -
You pretty much can if you find a parts car thats the same as yours but 4wd. Its not a simple or quick project.
What happened to the "Who's Who" page?
ShawnW replied to HillbillyLes's topic in Meet n' Greet. Your USMB Welcome Center
Les I hope you come to the Midwest Meet. -
snag on the clutch/trans install...confirm please?
ShawnW replied to ShawnW's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Forkspear had the opposite problem. Ratty2Austin I think I got 99% of that deciphered, no worries. I have decided to use the 1984 ea81 flywheel (the bigger clutch type one). I want to be 100 percent sure my new CCR engine isn't messed up by a wobble or anything. Anal me, sorry. My problem is I got the xt6 clutch kit. I asked before but still dont understand....is the disc itself bigger around or is it just thicker....asking because there was a post out here saying you have to turn the flywheel BIGGER on an ea82 flywheel for the xt6 disc but it don't think it said bigger in which way. Does my flywheel need to be turned THINNER or does the clutch surface area need to be EXPANDED for the xt6 disc? -
REVISED-------where to get????????????????
ShawnW replied to beachbum's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Headlight bezels? Stock 1983 ones were chrome. -
I went up and looked at it tonight. Im going to get it, just have to figure out how to get it back to Coralville. Its an 84 ea81T car, looks like Brian's car but Leopard print (rust). Car won't move in 4wd switched on and lights on the dash indicate the 4wd is engaged.
Car: My 83 Turbowagon project. Engine: ea81T Trans: 88 RX 5spd FT4wd These cars never came with a manual trans. The ea81 flywheel to engine bolts seem to be 9MM diameter. A VERY reputable source says that the holes on an ea82 flywheel are 1MM bigger than ea81 flywheels are. What has been done to get around this when using the ea82 flywheel or am I supposed to use the ea81 7 and 7/8 flywheel with the ea82 clutch kit?
I will take it off your hands.
Checking for cracked heads
ShawnW replied to Bratwerst's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Most junkyards give you a warranty on parts so you just pick the one with the lowest mileage that has a clean looking carburator and such. . When you pull the exhaust off and look up into the head sometimes you can see an extremely clean area like it was steam cleaned.
