ShawnW
Administrator
    7
Everything posted by ShawnW
  1. Larry has done a bunch of these swaps. Ill watch but I haven't had time to hit a yard in weeks.
  2. Is there a part that would make the car run strange only about around 52-55 MPH and above? At 45-50MPH its completely normal above that it surges and feels really weird like a sensor or something is angry. Doesn't matter what gear or how hard you drive it just seems to be speed related. Could I just unplug the ECM to see if its there or would a bunch of the other parts/sensors not work? I have always avoided this system and would just 'put a weber on' but the owner isnt going to like that idea and is very gas mileage orientated. The car is ea81 sedan FWD 5spd manual.
  3. Sure is hard to beat factory original paint when you can find the replacement panels. Nice job on the car!
  4. Do you have a writeup thread for the Forester Compass setup install?
  5. Take the driveshaft from the car and have it lengthened. Getting the center carrier bearing in the old 84 style body is usually hard to get dialed in right. I just measure the 4spd trans and the 5spd trans and have them put the difference in length into the driveshaft. I am sure the length is also posted here too.
  6. Hey you got everything working! Nice to see you the other day. I will keep an eye out for a bargain but I bet you will find one faster than I do.
  7. Are you saying the steering wheel points the wrong way now? That's pretty easy to fix if it is. Just move the wheel itself. I pull the nut, pull the wheel, lightly thread the wheel nut back on and test drive it (CAREFULLY!!!!!). Drive straight and then pull over and move the wheel where you think it would be straight then drive again to verify.
  8. The speed and wind resistance is going to come into play here...Ie, hauling something at 25MPh is a lot less than freeway speed. Don't turn your Subaru into a sailboat.
  9. Moved the topic over here for better exposure.
  10. I totally understand not liking a guy winning because he didnt build it but rather he bought it. At the same time, what a testimonial to the shops that did work on it. Maybe even a sponsor of the show that worked on it. A little reward for them wouldn't hurt anybody.
  11. Ive got one in the shop doing a head gasket. I had done a few engine rebuilds in the past both at CCR and the dealer before but never any work IN the car. Im pretty pleased with how much room there is to work. This one won't idle at all-falls flat to 0 if you let off the gas.
  12. I hope yours don't vibrate. I recommend drilling the hubs instead of the wheels.
  13. The Ea81 gauges are pretty easy. I would replace just the gas meter part if I knew the miles on the odometer were correct and everything else works on the existing gauge. I would also heed advice on the sending unit too, quite often see the sender bad and not often see the gauge.
  14. They don't want to refund your money? Are they willing to exchange the rack for another? Pay labor to replace? (not common).
  15. Yes, comes with the hardware usually. Everything you need should still be there unless it broke someplace strange.
  16. Crossbred Performance Kit! Allows for modern Subaru wheels and brakes on your old Subaru. Love the kit. I even did the brake booster and master cylinder. Its the safest option, it stops awesome, and it gives you a rear e brake. Make engine adapters!
