8
Everything posted by ShawnW
I think I paid $8 for the Autozone one.
Nice! Ea81 and Dual range would really make it a nice cool score.
Very cool. About 2.5 hrs from Denver too if you need to come to the junkyards here.
I personally think the best built ones are a combination but its hard to nail down a precise recipe. RX springs add about 3/4" I like the 2-3" lift kits the most. I think the 4" is too much and honestly the objective is to make clearance for larger tires. In my opinion, anything beyond 2" makes tires be far to large to turn, power, etc. Im not saying it can't be effectively done but trying to run 30" tires is crazy and adding massive amounts of lift blocks doesn't add to that much more tire working. I personally like the SJR offerings a lot but almost all of the lift kit builders seem to be putting out a decent product.
I got one at Autozone for a Nissan. Sorry I don't have the exact details.
I don't remember there being one. Theres a flasher relay. Usually its the fuse or or the turn signal stalk failing. Which car? This thread needs to be moved to the old gen or new gen forums depending on the car.
It threads onto the end of the axle to pull it thru the wheel bearings and hub.
Just dug this out of the toolbox after doing wheel bearings on a Brat. I forgot how handy this tool is. Despite being "RetroRoo" I seem to be working on a lot of old Legacy/1st Gen Outbacks instead of EA series cars lately. Both-- This axle tool is Expensive, but worth it. http://www.amazon.com/OTC-7535-Front-Installer-Subaru/dp/B000RJ2S5O/ref=sr_1_cc_1?s=aps&ie=UTF8&qid=1334286384&sr=1-1-catcorr Combined with a hub tamer(that you don't really need but a few pieces of it did make it quicker), I was able to easily do them. If you don't know what a hub tamer/grapler is: http://www.youtube.com/watch?v=EQLge25pUQI
Not exactly a "tech" question, but.......
ShawnW replied to hillbillyhans's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thats because nobody is calling him on it. You should be just as scared of that engine as an Ej25D like your Outback has. Except, todays technicians can probably figure out how to pull a trouble code or order a part for it without trying 3 times. All the same, I wish you luck in it-Im not a huge fan of that particular car but still a fan. -
Depends on who did the engine and what work it needs otherwise. I don't think the new engine adds to the value in this case unless its got more power, factory gaskets, and built by somebody that specializes in Subaru's. Otherwise, it could be worse than an original engine in my opinion. That car looks like one I see around Denver at the UPullIt yards. I would place that around $1800-2400 depending on how it drives and runs. -
Craigslist, Ebay and other places online of course. Lots of Sears/KMart stores closing around the country with store closing sales. Look at Lowes at the Kobalt tools too. I like theirs as much as the Sears ones.
The easy way to look up this belt is use an Alfa Romeo 164 with a 3 liter engine. Napa NBH 25050275. I stock these, $19.49 ea.
Nice choice on the box! I have a blue one like that. I started with the SS top but after about a year I needed more room and had to ditch it and put a box on the top of it. I miss the top but it was a lot of maintenance to keep it looking perfect which I really did end up with. I have had 0 problems with mine. Don't order the drawer edge guards they try to sell you. They show every fingerprint and look like crap fast. When I got mine I worked with a very experienced mechanic and I took a photo of every drawer in his box. I matched him tool for tool which cost me thousands of dollars to do but I never had to borrow one again. The other thing, when I left that shop, I had everything. Until I went to the dealer and bought another $10,000 worth to keep up with the master tech there. Its worth it if you plan on doing it for 20 years. Watch out though. You can score on Ebay, craigslist, etc. Most of the time for half of what you would pay on the truck plus no tax.
I do an average of 3-4 head gasket jobs a month and when at the dealer I did 148 workdays in a row of head gasket jobs. Yes. 148 cars in a row. Along with the fuel recall bulletins mixed in. I would say 5 percent DON'T fail before 200K. And fail in my book is: 1. Customer smells something hot and its dripping on the exhaust. 2. Oil/Coolant mix 3. 1/2 quart oil loss between oil changes at 3750 interval. Frankly, why argue it. They were so bad at one point the 2000-2004 Outback and Legacy cars were getting as high as 70/30 customer pay reimbursement from Subaru to have the fixed before 100,000 miles! I look at it like this. Its 4 hours book time to do the water pump and timing belt service. Usually the valve cover gaskets leak before 100K-at a minimum the tube seals do and its the same job to replace them. Thats a 1 hour book time. Already at 5 hours. Or. Pull the engine, replace the head gaskets, valve cover gaskets and intake gaskets and timing belt and pay an average of around 8.5 book time. An extra 3.5 or maybe $350 labor and $100 parts. Usually the heads are still flat but I deck them the bare min anyway so thats a variable expense. Still-maybe $500 more to have an engine last till 210K. Not so bad. That also gets you a free valve adjustment when I do it. They do run better after its done too.
"Ghost Walking"
ShawnW replied to ShawnW's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
When it does it, you have to let off the gas completely and let the tires try to grab. It feels like its going to put the car into oncoming traffic. Most drivers that experience it and aren't at fault in the situation want to take the car and push it off a cliff. Its bad. But its usually quite fixable with proper diagnosis. In my opinion, a dealer is not as likely to fix it as an independent. A dealer is going to try to say its the nature of the car, that they all do that, etc. An independent isn't going to have a worry or look over their shoulder mentality of lemon law worry. They can fix it and not worry about the customer wanting them to call Subaru and say they have a safety bulletin/concern to file. -
"Ghost Walking"
I think I would still leave this range of cars off the watch list. They are wonderful but I really think, bang for the buck the 2000-04 or the newest generations are better. Less quality issues with dash rattles, wheel bearings, etc. Still great cars. But for 5000 you can buy a really really nice 2003 or so car, and that would buy the worst 05-06 on the market-if one that cheap is around. -
"Ghost Walking"
If the car has a FWD fuse its in the under hood fuse box and is very small. The VDC/Traction control can typically be switched off with the button on the left side of the dash under the instrument cluster and to the left of the steering column.
