ShawnW
Administrator
    7
Everything posted by ShawnW
  1. If they moved I would pull the valves out in order and keep them in order. Then have the machine shop replace the guides and inspect the valves for any damage. Very unlikely it did any damage. IF it moved toward the stem seal its not as big a deal as if it came toward the top of the valve at the combustion end.
  2. I will go look at this if anybody wants me to. Its about an hour away from me and gas and a little $ for my time would be required but looks like a gem to me. http://fortcollins.craigslist.org/cto/2565445187.html
  3. Shipped today. I didn't get a notification from Paypal that you sent money, sorry for the delay.
  4. Why? You can borrow fuel pressure test kits at the parts store with a deposit. I don't see the point of monitoring it "permanent". New pump is cheap insurance and cheaper than most quality pressure testers. Unless you are a professional mechanic I wouldn't invest in a pressure test kit. http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_x_3150119-P_x_x?cm_mmc=CSE-_-Google-_-VALUE3-_-VALUE4&ci_src=14110944&ci_sku=3150119-40252&vehicleId=40252
  5. Remember this is a 9 year old car and to Subaru, that isn't going to be something they cover very often. Especially beyond powertrain 5/60 coverage window. By all means try it but don't be surprised when its denied. A rebuilt engine is probably your best bet. I sell a rebuilt longblock for $3059 for that model. Shipping is an additional charge of around $400 for both core return and new engine shipment.
  6. Email me the last 8 digits of the VIN number and I can see if my dealer can cross reference the part in the USDM catalog and get you a price on a kit to do the job. Gasket, center viscous unit, etc.
  7. If you didn't sell these already, I think I need these. Are they attached to the two hook on the RH side and the two big bumper bolts on each side attach to these? Mostly spot welded to the bottom side of the bed itself?
  8. Yeah, they are all the same from about that year until I think even today's 2012's have that same one.
  9. Very cool, thats near where the WCSS 11 was if I remember correctly we drove across the bridge from Astoria over there to see it. Cool park on the point. Lots of luck with the new Subaru and the mods and clutch replacement!
  10. Depends on temperature and such. It would be a cheap thing to try.
  11. Its possible its just the strut but you need to inspect it to be sure. It could be a crack in a spring or something too. Obvious during dis assembly.
  12. Many of us ship parts all over the world. Mick (link above is my fellow admin McBrat's website and he does an awesome job on decals and stickers).
  13. Its often cork but I would use the Fuji Bond from the dealer in place of it.
  14. It doesnt matter if they removed the knuckle even. As long as they don't remove the lateral links that connect to the rear crossmember it won't change anything. Short answer: No alignment needed.
  15. Oil won't fix it or even touch the problem if its a manual transmission. Auto's you can try "Trans X" which is sold at parts stores but I doubt this will solve anything its about 20% success rate in my experiences. Removing the driveshafts won't work on many levels. The coupler is in the back of the transmission and can be changed out in the car without removing the whole transmission. Its about $700 US in parts last I checked. I can order and ship the parts to you if you can't get them locally.
  16. Does it click when you try the start position? I would bet you need a battery or terminal on the positive is corroded.
  17. $204.01 plus 12.95 USPS shipping priority mail flat rate box. Paypal, credit card, or money order accepted. This kit works on 90-96 2.2L engines.
  18. Give me a chance to match their kits. All of my stuff is OEM. Website link below.
  19. Loose steering rack. Bad ball joint Axle nut loose Brake caliper loose lower control arm bushings Check warranty history and carfax maybe its been in a minor accident.
  20. Cant find the info on it either. Going to need to find an actual vehicle or seller of one to verify this I think. My gut says 2 3 point and 1 lap rear. I dont think the center 3 point starts till around 2005.
  21. The handle or the cables? If handle specify what color handle.
