N8NQU
Everything posted by N8NQU
  1. Can you guys tell me if they made a FWD wagon or all of them where AWD?????????? I am going to look at one this weekend and the owner does not know,he got for resale only.I do have a Vin #JF1GF2446PB801994 if this helps. Thanks Bill:confused:
  2. I have been looking on the forum and i have not found how to read the codes for the check engine light????Can someone please help????Thank you,Bill
  3. thanks for the help,mine has the black box.just a bad connection.Bill
  4. where is the ecm ( computer ) located.i want to know if the carb. model has one???thanks,Bill.
  5. I have no vibrations on the steering and this is only at a slow speed.how can i tell if the cone washer is bad ?????? Bill
  6. i hear a click or thump noise on the pass. side front of the car.you only hear it up to 15 mph and then it goes away.when i turn sharp right or left i don't hear the noise.is it the inner joint going bad?????thanks,Bill. 1992 loyale 5 speed 4 wd.
  7. has anybody got any axle shafts from a place on e-bay (parts-whse,lake toxaway,north carolina) for $29.67.are they any good????or is this to good to be true????? e-bay #8010079014 thanks,Bill
  8. i was wondering if it's a plug somewhere to short out instead of going and taking apart all 3 doors.???????
  9. can somebody tell me how to turn it off??????it's on my 92 loyale wagon.i want to keep all doors unlocked because i use the wagon for delivery,i drive all night and the light is driving me nuts!!!!!!!!thanks,Bill
  10. It's fixed,read original thread.thanks,Bill http://www.ultimatesubaru.org/forum/images/smilies/dbanana.gif http://www.ultimatesubaru.org/forum/images/smilies/dbanana.gif
  11. i got voltage on switch,when i presss up and down.it's got me wondering???
  12. my pasengers front wndow wont go down,i have the motor out and i will only go one way,i have tried 3 motors and 3 switches and all do the same thing ( ONE WAY ).can i get some input which way i should start looking,i need to get it fixed because i use it to deliver papers.thank you.Bill p.s. the other 3 windows work fine. after looking and tracing wires with the help of the FSM i got the problem fixed. i found a conector not pluged in all the way at the drivers side kick panel.thanks to all replys,Bill
  13. thanks i'll check it out and see what i can do about it.
  14. i will like to do away with the safety,i am, smart enough to put the E-brake on.my other 2 subs don't have it anyways.can somebody tell me how to bypass it??????thank you Bill. Merry X-mas to ALL.
  15. i'll keep it around for a while,when it gets warmer i'll do all the maintance stuff.Bill
  16. thanks for everyones input.they had 2 wires crossed and had the distr. bolts loose.put the timing at 20 Degr. put wires back to where they where ment to be and now after i drove it for 10 miles,it runs like a Champ.time will tell if it was worth the $300.00 dollars i paid for it.it came from burt subaru in colorado, and it's rust free.thanks again to all and Happy Holidays to All,Bill.
  17. it starts on the 2nd or 3rd try,it idles on it's own and smooth,when you go quick on the idle it will backfire and die.i drove it but it takes a while to get it up to speed.thank you for the green test conectors because i am going to check the timing and and all the wires. try
  18. i got a 92 loyale wagon today,it's backfiring from the intake when you give it gas,it's got 149k on it.i don't have any other information on it.i got it at a auction and it was a purple heart donation.evrything works on it including the 4wd.where should i start the troubleshooting.thanks Bill. i did not write that the wagon has fuel injection.
  19. i still don't know how to go about replacing them?????thanks Bill
  20. i am getting the 88 3door ready for winter and i found out that the rear wheel bearing is bad,can i get some information on how to replace it?????i have not done one on a subaru.i do have a 87 sub for parts and the wheel bearings are okay,how can i get to use them if the are the same anyways.thanks Bill.
  21. thanks skip, i put 12 volts to them and no sound,they are toast.it's time to put new ones somewhere under the hood.thank's again.Bill.
  22. it quit working,can somebody tell me where the horn relay is??? does it have one?????the fuse is good,got 12 volts to the horns but they wont work!!!!! thanks.Bill. http://www.ultimatesubaru.org/forum/newthread.php?do=newthread&f=2# Brick Wall
