Everything posted by N8NQU
Can you guys tell me if they made a FWD wagon or all of them where AWD?????????? I am going to look at one this weekend and the owner does not know,he got for resale only.I do have a Vin #JF1GF2446PB801994 if this helps. Thanks Bill:confused:
1992 loyale wagon,need help with codes???
N8NQU posted a topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have been looking on the forum and i have not found how to read the codes for the check engine light????Can someone please help????Thank you,Bill -
thanks for the help,mine has the black box.just a bad connection.Bill
where is the ecm ( computer ) located.i want to know if the carb. model has one???thanks,Bill.
I have no vibrations on the steering and this is only at a slow speed.how can i tell if the cone washer is bad ?????? Bill
i hear a click or thump noise on the pass. side front of the car.you only hear it up to 15 mph and then it goes away.when i turn sharp right or left i don't hear the noise.is it the inner joint going bad?????thanks,Bill. 1992 loyale 5 speed 4 wd.
bump
has anybody got any axle shafts from a place on e-bay (parts-whse,lake toxaway,north carolina) for $29.67.are they any good????or is this to good to be true????? e-bay #8010079014 thanks,Bill
i was wondering if it's a plug somewhere to short out instead of going and taking apart all 3 doors.???????
can somebody tell me how to turn it off??????it's on my 92 loyale wagon.i want to keep all doors unlocked because i use the wagon for delivery,i drive all night and the light is driving me nuts!!!!!!!!thanks,Bill
1992 loyale,power window help????? ( FIXED )
N8NQU replied to N8NQU's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It's fixed,read original thread.thanks,Bill http://www.ultimatesubaru.org/forum/images/smilies/dbanana.gif http://www.ultimatesubaru.org/forum/images/smilies/dbanana.gif -
i got voltage on switch,when i presss up and down.it's got me wondering??? -
my pasengers front wndow wont go down,i have the motor out and i will only go one way,i have tried 3 motors and 3 switches and all do the same thing ( ONE WAY ).can i get some input which way i should start looking,i need to get it fixed because i use it to deliver papers.thank you.Bill p.s. the other 3 windows work fine. after looking and tracing wires with the help of the FSM i got the problem fixed. i found a conector not pluged in all the way at the drivers side kick panel.thanks to all replys,Bill
clutch safety switch???? 92 loyale
thanks i'll check it out and see what i can do about it. -
i will like to do away with the safety,i am, smart enough to put the E-brake on.my other 2 subs don't have it anyways.can somebody tell me how to bypass it??????thank you Bill. Merry X-mas to ALL.
need some input???? " Fixed"!!!!!
i'll keep it around for a while,when it gets warmer i'll do all the maintance stuff.Bill -
thanks for everyones input.they had 2 wires crossed and had the distr. bolts loose.put the timing at 20 Degr. put wires back to where they where ment to be and now after i drove it for 10 miles,it runs like a Champ.time will tell if it was worth the $300.00 dollars i paid for it.it came from burt subaru in colorado, and it's rust free.thanks again to all and Happy Holidays to All,Bill. -
it starts on the 2nd or 3rd try,it idles on it's own and smooth,when you go quick on the idle it will backfire and die.i drove it but it takes a while to get it up to speed.thank you for the green test conectors because i am going to check the timing and and all the wires. try -
i got a 92 loyale wagon today,it's backfiring from the intake when you give it gas,it's got 149k on it.i don't have any other information on it.i got it at a auction and it was a purple heart donation.evrything works on it including the 4wd.where should i start the troubleshooting.thanks Bill. i did not write that the wagon has fuel injection.
Need Advice On Rear Wheel Bearing????
thank you,i will give that a try.Bill -
i still don't know how to go about replacing them?????thanks Bill -
i am getting the 88 3door ready for winter and i found out that the rear wheel bearing is bad,can i get some information on how to replace it?????i have not done one on a subaru.i do have a 87 sub for parts and the wheel bearings are okay,how can i get to use them if the are the same anyways.thanks Bill.
1988 3 door (horn problem??????)
thanks skip, i put 12 volts to them and no sound,they are toast.it's time to put new ones somewhere under the hood.thank's again.Bill. -
Bump, -
it quit working,can somebody tell me where the horn relay is??? does it have one?????the fuse is good,got 12 volts to the horns but they wont work!!!!! thanks.Bill. http://www.ultimatesubaru.org/forum/newthread.php?do=newthread&f=2# Brick Wall
