N8NQU
Everything posted by N8NQU
  1. everything is hooked up and when the wife moves the E- brake they both move the same distance.
  2. both arms move about the same distance,i had the wife pull on the E-brake and with the tires off i was looking at them move.it was working fine untill last saturday when i put theE- brake on and the car started moving.the E- brake grabs zero.
  3. good score you will like the 3 door,i drive ours only the winter but i sure like the room that they have and the looks of them.i am going out to the garage to take a look at the E-brake again.
  4. no resistance it pull up a okay and the cable that goes to each front wheel moves but it does not grab the wheel.when the E-brake is on you can still rotate the front tires.i'll have to go look at splitter bar.
  5. i have adjusted it al the way on the rod by the E-Brake and it still does not want hold the car,you can push the car and it moves just like it's no brake both front wheels move free,.the brake was working untill last weekend and it started acting up.thanks in advance,Bill http://www.ultimatesubaru.org/forum/newthread.php?do=newthread&f=2# Brick Wall
  6. i took the kick panel off and droped the fuse box,then i found the connectors,switched them and it worked NO EGR LIGHT.so i guess i'll wait now untill it has 120K so the light will come on again.thanks for the info.Bill.
  7. the T-Belts where replaced at 57K.I do like your reminder of the egr light to check the belts.Bill.
  8. Thanks,i'll give it a try and i'll you know.Bill.
  9. i just turned 60K on it and the EGR LIGHT came on,i know it's programed to do that.how can i RESET IT?????thanks,Bill.
  10. thanks on the reply,i'll look at the cable,i hope it's that simple.Bill:wave:
  11. Can somebody tell me where the cold( what is cold??? rpms) and operating temp idle is 700 rpm and do i do the cold first and then the warm?????Bill:wave:
  12. i'll try the MMO and carb cleaner,is the screw that faces the spare tire???? i tried adjusting it and it did nothing.choke is working okay.Bill
  13. 1987 gl wagon 5 speed D/R it idles about 2000 rpm and when warm it does not come down,still 2000 rpm.can somebody tell me how to adjust the carb??? i would like to also adjust the low idle also????thanks in advance for the help from this board gives.Bill:wave:
  14. I just got mine today,me and my wife LOVE THEM.thanks for the good work.Bill :wave:
  15. i thank everybody that has posted because it sure has made it so easy to know all the info.that you guys have learned from working on the SUBARUS.i will post when i put the u-joints in the driveshaft. :banana:
  16. i thank you for the thread,i went and looked at it and i will try to do them myself with the help of the FIRE WRENCH. :banana:
  17. well this is what i found,i took the one out of the wagon and then the 3 door,put them side by side and they are the same length.i now have the 3 door back on the road again.how can i get these u-joints replaced so i can put my wagon on the road??????thanks again for the quick helping hand,you guys are great.Bill:banana: :banana:
  18. the 88 3 door 5 SPEED D/R the u-joint on the rear end just went bad,can someone tell me if the one of my 87 wagon 5 SPEED D/R work untill i can put a u-joint on the car?????i need to know ASAP so i can fix it tonight so i can go to work in the morning. thanks a million Bill.:wave:
