Everything posted by rguyver
its the VSS speed sensor it needs to be hooked up to the dash wiring
EJ hydraulic clutch pedal box on EA81 car
rguyver replied to LeoneTurbo's topic in Subaru Retrofitting
they never made any Hydraulic clutch trans SUBARU prior to 1990\91 so i dont know what car you have seen that has a EA engine and hydro clutch ? the EA cars are a lot smaller and the peddle set from a impreza or legacys. will not fit , the 4 bolts for the booster are the same but that's it , the part that bolts up under the dash is different and the throttle cable mount is not part of the peddle set on the EJ cars . -
you will need to take all the heat shielding off the up pipe or get an aftermarket one, it rubs a little if you dont .
when i did my brat i had to custom build a peddle set out of the WRX and the brat, lots of cutting and welding , i also had to move the hydro master in more so it was shorter on the shaft , redrill the pin for the leaver and relocate the throttle cable , i built a jig that simulated the firewall so i could weld the peddle set in the proper location . not an easy task and i dont know of any EJ peddle set that would bolt up with out major mods . -
Disconnecting Front Handbrake
rguyver replied to rxleone's topic in Old Gen.: 80's GL/DL/XT/Loyales...
you may think its a 4 wheel e-brake because the locked 4wd not awd , when you apply the e-brake and lock up the front it forces the rear to lock up because there is no center diff on the older cars , same goes for the VLSD center diff when you apply the rear e-brake in a EJ car you will be slowing the front wheels a little bit too , some thing to think about when you drift an EJ car so you dont under steer in to the ditch STI's open up the DCCD center diff when you use the e brake for drifty fun -
all the older EA81 short shafts with the 23 spline cups i have seen use a different shaft spline so the DOJ will not fit on at least not any OEM shaft . if you have a 80-84 short shaft for a EA81 car with 85-90.....EA-EJ 25 spline cup on it i would like to know what early short shaft you used ? the splines are similar but are not exactly the same that they fit . nothing is written in stone so maybe at some point they changed the the shaft splines in the later EA81 cars but we didnt get many here after 1984 except the hatch / Chaser .
I have some adapter plates left and looking to sell off the rest before i do a new run . 100$ US + shipping or if you buy two ill do free shipping in Canada or U.S. Pay pal account rguyver@hotmail.com they are CNC cut out of 1/2" T6061 alu. and are taped for standard bolts, can be changed , or left blank . I will bring the remaining plates to the WCSS11 and they will be 100$ cash at the show if i have any left at that time, reserve one if needed. Thanks Regan Link to the old thread http://www.ultimatesubaru.org/forum/showthread.php?t=77490
fuel lines will be ok for a N/A 2.2, i have used the turbo pump but any good fuel injection pump will work as long as it holds a constant 40+ psi , if you are going to go over 200HP you will need to upgrade the fuel lines and return line , i used the stock supply line as the return and put in a new 3/8 main supply.
ya they did some odd stuff when they had the Loyale , Impreza, and legacys all in production ya never know what to order some days
i just pulled a set of 1993 2wd Imp. axles from a EJ 1.8L automatic out and it had the 25spline unless the 5speeds are 23 ? but from what i know all EJ 5speed 2wd trannys have the same guts as a EA turbo 2WD and they use the 25spline axles ?
from what i have seen all Impreza axles have the same ends as the XT6 and you need axles with the smaller inner splines to fit the non turbo low range tranny ? then you will have to take the upper boot off and joint from a 1985-86 turbo 3speed auto tranny , and put it on a xt6 shaft and outer joint or Imp. the 85-86 turbo 3speed auto axles have the smaller tranny splines but use the bigger cup joint as a RX or XT6 , basicly you will need to find a inner cup with small splines that fits your XT6 shaft . and no i haven't seen a axle that fits the 5lug hub and fits the smaller tranny ends . but i could be wrong , stranger things have happened
is the only diffrence in the DELUXE and DUEL MODE controllers the addition of the stock dial and switch , i have the stock ones and dont need to pay for new ones ? also no dash display wires ?
http://dccdpro.com/store//catalog/product_info.php?cPath=21&products_id=29&osCsid=f0ca58a5957ff9c8ec2d631a2d4b64e8 "Aftermarket standalone Automatic DCCD controller for JDM and USDM 6 speed transmissions as well as older 5 speed DCCD transmissions. Did you swap the transmission in your car and need to control the DCCD? Running without a controller risks breaking expensive drivetrain components. This product is specifically designed for swapped cars, and includes everything required for automatic and manual DCCD operation, including a properly designed and handbuilt custom control module in a water resistant enclosure, with a nice adjustment knob for setting the locking force, this system is infinitely adjustable between fully locked and unlocked. "
thanks thats the answer i was looking ! i have also had problems with 04's centerdiff controlers not releasing in a slow speed (parking lot) turns in auto mode and causing a constant banging from the drivetrain as it overcomes the load on the diff . im thinking ill go with the DCCDPro. if the stock comtroler is going to give me problems thanks
excellent work on the 6speed swap hoping to get to my brat 6speed 2.5L swap this fall and i have the full car wiring harness including the DCCD comp. and g-sensor from a 2004 and i have bin told i dont need the wheel speed sensors for it to work properly they dont relate in 04 ? its only for the active stability control ABS comp. only ? just wondering what your thoughts are if you looked in to just using the stock DCCD comp. ? im prob. going to cut and weld in the tunnle out of a newer impreza or leg. to make it fit at all with out hitting .
i dont have any pics of building it but some time later ill try to get pics of it installed .
not to bad mouth any shop but out of all the shops i know of i would only trust two that i would let touch the inside of a subaru tranny , me and a local rally shop , almost everyone i have heard of messing with them some how screw it up all it takes is a missing shim or over torquing the case and they have problems. i would go with a good use one next time it gives you problems
custom cross member , i welded the old 4speed and the EJ 5speed along with some square tubing so i could use the EJ STI tranny mount . i dont have any pics now but ill try to get some up some time . best thing to do is have the tranny in the car and held up with a jack and start trying to fit, cut and weld something to hold it up , dont forget exhaust pipe clearance.
if the shaft is built and spun on a lathe it would not need to be balanced as long as its not bent .
the diffs are the same in the EA and EJ trans
i thought so too but i havent found that conversion shorter shaft for the front that has the same shaft splines as a EA82 or newer so i just cut them so i can get the bigger joints at each end .
if you are going to keep the 4 lug yes 1985 and newer turbo axles would work too for a AWD EJ trans swap or change out the shafts in the tranny for the smaller ones from a non turbo EA tranny to be able to just use the stock shafts , but you will have to split the case to swap the shafts .
the machine work and weld would be around 200$ an axle + core depending on the work needed or 200$ + the cost of 2 axles if you wanted to keep the 4 lug because you would need a EJ inner and EA outer ends put together .
i havent decided what the WRX engine and tranny are going in too yet but ill keep you in mind if i want to sell them . i may sell it as a complete package for a swap in to a older EA .
