Tiny Clark
Contact Methods
Website URL
http://
Location
Germany
Occupation
Avionics Engineer
Ezboard Name
TinyClark
Tiny Clark's Achievements
Certified Subaru Nut (8/11)
11
Thanks all. Baffle plate, huh? Sounds like another name for an oil leak door. Well, hopefully I'll be able to sell it this way. I'll check the PCV today, but I don't think that will do it. I changed that not too many miles ago when my oil pump seal was leaking. Only take a few minutes to check it out though. As I said,the seal didn't make sense to me anyway, since it doesn't really seem to leak when sitting static, only when the oil is pumping.
Transmission out of the way doesn't make it an easy fix, at least for someone who can't lay on the ground too much anymore. I'll search again, but it looks like the only place it can be coming from is the bell housing, which means rear seal. I also want to say that you regulars in here have been great over the past years. I learned a lot about Subies, and I appreciate the help that I always received before.
My '96 has an oil leak in the rear of the engine somewhere. The cam cover on the passenger side is fine, and I can't see anything else. It is dripping right onto the exhaust manifold and stinks badly when stopped. It almost seems like a bad oil pressure sensor, as it only leaks when the engine is running. After shut down, I just get a few drips (residual?). It doesn't leak while static. I hadn't seen anything on this before, but then again, I wasn't looking. Are rear main seals a real problem? 146k miles and ready to sell. I really don't need it anymore in So. Georgia.
If you can't afford to have it changed right now, it may last a bit longer. If you can swing a can/tube of grease and a can of carb cleaner. Clean it up as much as you can, get some grease in there, then take some nylon tie straps, cover the boot with a plastic garbage bag and zip tie it on at both ends and one in the middle. Make sure you wrap it up in the right direction so the end doesn't get caught in the draft. I did this on a Geo and it lasted 3 months.
