Tiny Clark
Everything posted by Tiny Clark
I'll reply to your private message as well, since I don't know what a WRX is. 1. You didn't say what a deal you got on the car in your original post. I certainly wouldn't have posted the way I did if that was the case. 2. Sorry, but laser cut, zircon encrusted spark plugs aren't going to give you any appreciable HP gains, regardless of what all the advertisements state. 3. If you put on a custom exaust, which would be your best bet, make sure they install an exhaust. 4. Before you go messing with the intake, be aware that putting a cone filter on it without having some way to get cold air to it won't help. 5. Try out some chrome moly muffler bearings and high compression tire valves, you snotty little $hit, and spent a few nights at Neverland Ranch.
Can I get a whopper with fries and a coke? OK, I'll take a McFish with fries and a Dr Pepper. Sorry... but I'm old, and I'm happy; I was once like you are now, and I know that it's not easy, to find a car that has all the things, that I cry for... (my sincerest apologies to Cat Stevens) Why buy what you didn't want?
It's my understanding that the fluid in the converter doesn't just flow in and out like that. I do know that years ago, a hole had to be drilled on Chebby T.C's to drain them. Nature of the beast I think. Probably the best thing is to change fluid regularly. And if you do go in to have it rebuilt, find a local ATRA certified tranny place, and stay away from the powersellers at AAMCO, Mr. Transmission, etc. If the guy at a local shop stands by his work, he'll give you phone numbers of satisfied customers you can call. Remember, it's your 1,500 bucks.
Usually, the ground side is the switched side. 12V is fed to one side of the relay and it awaits a ground to complete the circuit. On some cars, the ground is supplied directly by a thermal switch. Apparently, as Josh POINTED OUT, on your car the ECU supplies the ground. Download the diagram at the link he posted and go from there.
1. Check and clean battery terminals. 2. Have you tried jumpstarting? 3. Do you get a loud click from the starter when you turn the key? If so, then the solenoid contacts inside the starter are bad, as they get arced up after many starts. If not, make sure the 12 volts from the key switch is getting to the small terminal on the starter.
All three of these look like they are from the same source, BOB. I take BOB and everyone else with a grain of kosher salt. I've had many cars over the years, never submitted my oil for analysis (although I could probably have our fuels folks do a spectrum check on it for free) and always had over 100k miles on them, still running like the day I bought them. My suggestion: stick with Mobil 1, use the weight appropriate for your local temps, change it regularly, and leave your worries in the rear view mirror. That is my 2 Euro-cents worth.
