Everything posted by Tiny Clark
95 subaru legacy l adjusting the clutch tension?
Tiny Clark replied to BulletRide's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJa, If you adjust the clutch cable to where it's like putting a little pressure on the pedal, you will most likely fry your throw-out bearing, as it will be spinning all the time.
Burnt exaust valve, pull engine?
Tiny Clark replied to chico00's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXChico, call these guys first... Rising Sun Engines, Inc 2695 Hwy 32 Chico, California 95973 Toll-Free Nationwide: 1-800-660-4664 </B>Local: (530) 895-0300 http://risingsunengines.com/
Sticker removal?
Tiny Clark replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGoo-Gone will not hurt the paint. Either will charcoal lighter fluid if you have some of that laying around.
could this be the problem...?
Tiny Clark replied to 98legacywv's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd take some lightweight sandpaper to your dipstick, it makes it easier to read.
Need Help Pimping my 2003 Forester
Tiny Clark replied to BogeyExova's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPimp it and call it a SLUF= Souped-up Low Ugly Forrester. Of course, another f-word could be substituted.
Tribeca B9 Photos
Tiny Clark replied to hklaine's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLMAO firstwagon. Might be a bit wet in the rain and snow as well. Maybe it comes with a gore-tex blanket.
No Spark
Tiny Clark replied to JohnCalder's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIn the Air Force, we call this FM - frikkin' magic, or something very similar to that. The only diodes I know of that he may be talking about are the rectifryers in the alternator.
2005 Outback Dual Exhaust?
Tiny Clark replied to Sweet82's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNo problem, people who drive XC90s are only pretending they will drive off-road.
Tiny Clark replied to chico00's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDon't they have Subaru engines at those used japanese engine places in CA? Maybe you could check out that possibilty.
Problem with rear defroster
Tiny Clark replied to a post in a topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe fuse could be bad, but it could also be the relay (in the fuse box) that controls the defogger. The switch supplies a ground to the coil of the relay, which in turn supplies the 12 volts thru the fuse to the window grid. The 12 volts for the positive side of the relay coil comes from the ignition switch.
2000 Outback A/T PROBLEM
Tiny Clark replied to gtwagon's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes it shift OK manually? If so, maybe the TCU or ECU. Sure would be nice to go back to the simple life of a vacuum modulator instead of an array of solenoids.
Just took my Mom's '03 GT sedan for a Easter flogging!!
Tiny Clark replied to shortlid's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIs this waht our high skools are produsing now? Oh wait, I have a senior in the house, and the answer is, like, yes!!
Tiny Clark replied to BulletRide's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDitto, bullet, I'm having a hard time understanding what you are describing. You do want to have about a half inch of free play on the pedal, or you'll fry the throwout bearing and possibly smoke the clutch plate if it's too tight.
Upper Engine Clean?
Tiny Clark replied to 4Sugars's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXBlitz, Seafoam's homepage doesn't say anything about changing the oil right away, even tho they mention using it in the crancase: When Added to Crankcase (Oil) Frees sticky lifters and rings Increases R.P.M.'s vacuum and compression Cleans dirty parts Removes moisture Cleans PCV valve systems One pint treats 10 quarts of oil (avg. 1 1/2 ounce per quart). I would think if this broke down the oil, it would be mentioned. But just like any other cleaner, it'd be a good idea to drain the oil and get all the crap outta the system.
tick of death in 2.5 2003 outback
Tiny Clark replied to Boddi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI din't know what the frikkin' clearance was, and didn't think it was as large as .010 either. I was just trying to 'splain it in some sort of relevant terms that would make sense to someone who doesn't know what a piston skirt looks like. Boddi, have a look at this: http://www.canadiandriver.com/articles/jk/020320.htm
2000 Forester Hates Wet/Damp Starts
Tiny Clark replied to patricko's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAgree with 7sis's, usually damp weather brings out the worse in the High Voltage area of the ignition system, usually attributed to plug wires. Seven sisters... sounds like a small convent.
Legacy horsepower chart wanted...
Tiny Clark replied to baboonia's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm sure all figures will be lower than you'd like. I just call it a performance toad and live with it.
Head gasket replacement/cam removal
Tiny Clark replied to Max Power's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm not a subie motor head, but give me a chebby small block... I can't see any reason for this, unless the cams are on top of the head bolts. I don't know if I would go to the trouble of R-squaring the gaskets without having the heads shaved or checked for flatness tho. If shaved, the valve lash would need to be adjusted, and always go on the err side of loose.
Tiny Clark replied to Boddi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPistons are slightly smalller than the cylinder bore, which is one of the reasons we have rings on the pistons. With even .010" of an inch clearance, which is ABOUT the thickness of a sheet of paper, a piston will wiggle, or slap, in the cylinder if it isn't long enough to keep it from cocking back and forth too much. huh, huh, he said "cocking", huh huh!!!!! The subie design of these pistons suck. Let's meet the engineer in a dark alley somewhere... Zappa also said, "The crux of the biscuit, is the apostrophe"
Tiny Clark replied to Boddi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe Subie engineers decided that in the best interest of public safety, they should remove just about all of the piston skirt (the two longish tangs at the bottom of the piston) that used to assist the piston in sliding back and forth in the cylinder.
Mobil 1 15-50 and piston slap
Tiny Clark replied to cookie's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was looking at the open engine picture displayed on the subaru.com last week. I don't understand what the bad significance of longer piston skirts would be. With an alloy material, the total mass can't be that much of a diff, and the friction would seem to be negligable. Of course, I'm not dining on raw fish and wine made out of rice... Maybe they should have taken the material saved on the pistons and used it for a different cup holder.
Tapping into the Instrument Panel Dimmer
Tiny Clark replied to Charlie05's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLot of ways to do it, but maybe it would be easiest to have a small flashlight handy!!
Greetings from Western Wisconsin.. own 2 OB's (05XTWgn, 02EBOB)
Tiny Clark replied to wadcobilxt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI second the fumoto valve idea. One of the better investments I've ever made.
Do I need a new clutch
Tiny Clark replied to suprmanlives's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat do you mean by every gear is like neutral? Can you put the car into first or reverse with it shut off and push it with no resistance?
radio/tape player troubleshooting
Tiny Clark replied to aja573's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhat's a cassette?
