Tiny Clark
Everything posted by Tiny Clark
Keep in mind that an LED doesn't work the same as a light bulb. It may not come on until the dimmer is set to a certain point and the diode junction is "energized", and I don't believe you'll see much dimming action once it is on. If you want to use the dimmer, it's my opinion that you'll have to replace the LED circuit with a 12 volt peanut bulb of some type from Radio Shack. Does the ligher receptacle have a light ring around it that dims? That may be the easiest place to tap into. There should only be a ground, 12 volts for the lighter, and the lighting wire.
Bad NGKs ???
Tiny Clark replied to old97's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The resistance of the plugs themselves will be completely open. -
This torque bind is a crazy and temperamental little vice. I have a set of winter tires I put on my Legacy, and didn't really pay attention to the tread depth on them. After I changed them this past winter, I heard a ticking sound, especially when stopping and turning to the right. I thought I had screwed up or missed something during the tire swapover (yea, fat chance of that happening:)). After I looked at the tires, I noticed a very slight difference in wear between the two front tires. I swapped the front and rear passenger tires and voila, no clicking!
Bad NGKs ???
Resistance will probably be 10 to 20 K Ohms. As long as the four wires are relatively close to each other, no problem. -
When the alternator in my 96 went bad, it would charge at certain RPM's only. Don't forget, the drain on a battery is huge on newer cars with just the engine running, i.e. fuel pump, injectors, ECU, ignition, abs, etc... Autozone, Advanced, or some other parts store may check the alt output for free. If there is any drain on the battery with the key off, you can check that with a stop/turn/parking lamp. Just pull off one of the battery leads, put the metal casing of the lamp on the battery terminal, and touch the battery lead to the lamp connection bead. If you get a decent glow, you may have a problem. Forget the fuel filter, it isn't causing this problem.
The worst thing about cruise controls is people don't speed up to pass a car on the interstate if someone is behind them travelling at a faster rate. Maybe they forget they can still use that skinny pedal on the right with CC engaged. The sign in most states that says "Slower Traffic Keep Right" is a law, not just a suggestion. They will ticket you on the autobahn for impeding traffic.
I am looking at the only schematic I have of the fuel gauge system. It shows the two sensors are in series with each other, comprising of variable resistors. This resistance is fed into a CPU located in the instrument cluster. It shows the outputs of the CPU going to the light and gauge. Maybe once the resistance reaches zero, or very close to it, the light is supposed to come on. Doesn't make sense to me doing it this way, but I run into this all the time on our airplanes. Maybe someone can verify that fact that there are only two wires coming off the sensors. If not, I don't know where the hell they got this diagram from.
