Tiny Clark
Everything posted by Tiny Clark
Anyone have problems with their rear hatch lock on a Legacy? Mine is a '96, and the solenoid sounds like it's popping when the driver's door lock switch is engaged and disengaged, but the damn door still won't open. Of course, this happens intermittently... Was wondering if something common breaks back there before I tear it apart. Tiny
Can't speak for most European countries, but most German cars have a second detent on the turn signals to turn on the parking lights on one side, a requirement on many unlit streets. Actually, only the rear tail lamp comes on, and there is a small bulb in the front headlamp housing that illuminates.
You can drain it, make sure you measure how much came out, and refill it with that amount. Drive it for 500 miles or so, drain it again, then do it a third time. This will get plent of good fluid into the tranny and converter for less than $20. Or you can pay for the flush at a tranny shop. One thing I don't understand though is this: I have been told that fluid in the torque converter does not run through it unless the car is driven, so I don't know how much better a "professional" flush would be vs. draining a few times. I know tranny shops used to drill a small hole in the T.C.'s on chevy's to completely drain them when they had them removed during a tranny rebuild, then install a plug.
Someone chime in because I'm probably wrong, but I'm going with what most auto manufacturers are doing today, which is using solenoids to control all the gear changing. Don't know if your year Subie has a TCU. Sometimes I wish for the good old days when all that was used was vacuum, speed, and throttle pedal position for downshifting.
Add in a small bag of self lighting charcoal and few bic lighters on stuff to carry in the back in case of emergencies... I never experienced flat spots on tires in the Alaska cold. An engine block heater would be good. I tried the coolant hose type for my son's car, and it didn't work very well. You can also buy a plug-in battery warmer. Tiny
Have your alternator tested at Autozone under load conditions. Seems like I had similar problems when my alternator went tango uniform. Used to be, in the old days, you could run a car for days on a fully charged battery. With everything being electrified now, you probably wouldn't get an hour down the road.
