2
Cougar last won the day on June 20 2016
Cougar had the most liked content!
Contact Methods
Website URL
http://
Gender
Male
Location
Anchorage
Interests
Electronics, woodworking,music,flying
Occupation
Telecom Tech
Ezboard Name
Cougar4
Referral
Subaru sites.
Biography
Like to keep up with car technology and tinker with electronics.
Vehicles
'01 LL Bean Outback
Recent Profile Visitors
Cougar's Achievements
Elite Master of the Subaru (11/11)
88
Loyale 2.7 Turbo started following Cougar
When you checked the fuses in the dash panel, did you check to see if power was getting to them? I assume it is the Warning lights you are referring to that are not working, correct? Fuse 5 in the Main panel supplies power to the Ignition relay. Check for power on the fuse and at the relay. Make sure the relay is working properly.
I think the power to the injectors is provided through the Main Relay, along with other engine circuits. They are all tied to a supply line from the relay. I suggest you look for a bad splice connection, possibly in the harness, for the two injectors having trouble. Also, you are correct in thinking the ECU turning on the injectors by completing the ground connection to them and power is supplied to them whenever the Main Relay is ON.
Your understanding of the battery indicator light is correct. Current has to pass through it to provide power to the exciter inside the alternator. The battery light should turn ON when the ignition is turned to ON, like the rest of the warning lights do. If that doesn't happen then follow the good advice given by FerGloyale by grounding the B/W wire going to the alternator. If the light still doesn't work then either the light is bad, power from the ignition isn't getting to the light, a blocking diode inside the cluster is bad, or there is a wiring problem on that circuit. The alternator provides a path to ground normally until it generates the field. Then there is a charge on the windings and the current stops flowing to ground and the light goes out, unless there is a problem with the alternator.
ign relay
Cougar replied to subpoop's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The ignition relay ties to connector B93, which is shown in the drawing of the bulkhead wire harness on page 119 (page 1310 of the PDF), in the wiring section of the physical manual. You can find information about the power to the ECU (depending on which model you have, MPFI or SPFI) on pages 22 and 30. Along with the power to the ECU, make sure that the grounds to the ECU are good and making connection to the body and engine. The details for the power supply routing starts on page 14 (Part 5) of the wiring section. -
The trouble may be within the alternator. To see if this is the case disable the alternator by removing the small wire connector going to the alternator. Start the engine and see if the trouble has cleared. It id does then the alternator may have some bad diodes inside it and too much ripple voltage is occurring.
This could be a warning that the battery is failing. I suggest you have it checked and it would also be a good idea to clean the battery connections using the proper cleaning brush. What matters is the battery post contact surfaces, not the outside clamp surfaces. They may not be an issue but by doing that you will know for sure that they are making good connection.
Alternator not charging
Cougar replied to Squidbilly503's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check for a loose fusible link connection, it is a fairly common issue. They are located in a small plastic box mounted on the coolant reservoir. -
If jumping power to the black ignition switch wire doesn't help solve the issue then the next check I would say is the Ignition Relay. It should be located under the dash, upper left side. Try tapping on it with a screw driver handle to see if that will help make contact. If that works, replace the relay. The trouble you described makes it seem like a relay issue. I don't know how you got near a twenty volt reading. If that is really true then you need to replace the alternator immediately.
Fuel pump issues
Cougar replied to dp213's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Thanks for the heads-up on the controller Naru, the turbo model engine does have one. From the details given by the OP it seems there is a bad wire connection somewhere in the power circuit for the pump.
