2
Everything posted by Cougar
Weber install: backfire from intake.
Cougar replied to TheYeti's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Those are good ideas Skip. -
The pedal should be left alone while the ECU does its' routine. You may have to redo the procedure. The CTS is the coolant temperature sensor for the ECU. It is not the same sensor used for the temperature gauge in the dash. It is there for the ECU to determine what the engine temp is so it can adjust the fuel mixture correctly. One of the most common problems for bad fuel economy. You are right about a leaky injector making the engine hard to start. The injectors are most likely fine but they are just another possible area of trouble.
Thanks!
Cougar replied to stevetone's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Another happy Soob owner. It's a good thing. -
Help!! ea-81 ignition, no Spark
Cougar replied to croak's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You may change your mind about getting two pickups when you find out the price of them. Here is a link to a previous thread that has some prints and info that may help you out. Looking at the print it does appear the ignition relay makes a ground connection. http://www.ultimatesubaru.org/forum/showthread.php?t=79249 -
By placing a test light probe on the minus side of the coil and ground you should see light pulses as you crank the engine. It sounds like the pickup in the disty is bad. -
There may be a couple of problems going on here. The starter solenoid contacts are at the right age where they start giving intermittent problems like you stated. You can replace the contacts for around $12 dollars or replace the whole starter with a rebuilt unit. You also stated that the starter works but the engine doesn't fire up. There may be a problem with the ignition switch or wiring causing this trouble.
Thanks for the confirmation TY. I appreciate it. I can only think of a couple things at this point. First thing is just to satisfy me really and is pretty simple to do. Since the disty was pulled and to verify that the disty position is correct could you set the engine to TDC and then check to see if the disty rotor position is where it is supposed to be? The second thing is I think some carbs need a spacer to work correctly. Since I don't really have a lot of carburator experience I am not sure if that will help in this situation or not. -
92 Loyale pw quit working HELP!!!
Cougar replied to subieluvr's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The front passenger switch still may have a problem since it has to pass the power also from the switch on the driver's side. Without checking for voltage at the switch it is just a guess as to where the problem is. You could try swapping the front switch with the rear ones to see if that helps. Most likely those switches are dirty also put broken wires in the door jamb is another common trouble. -
Looking at the somewhat low vacuum reading of 14.5 inches caught my attention but I forgot where you are located. Since your elevation may be around 5,500 feet I needed to adjust the reading. By adding 1 inch per 1,000 feet from MSL the reading then looks better. In order to get my story right on this dilemma, am I correct in thinking that the only thing worked on or changed (besides the CAT) since the engine was working correctly is the carburator? The disty wasn't removed and replaced, or anything else? -
Glad to hear you made some progress at least. I still feel the problem you are having is due to either the valve timing is off or the disty position is off by a tooth. Did this problem start happening after either of those areas were worked on? We may be able to prove if this really is the problem by checking each cylinder while it is in the firing position. Then force air into the cylinder through the sparkplug hole, like you would on a leak down test. If you get air back up the intake you will know what to do. Edit: Looking at your last vacuum test reading of 14.5 pounds seems to confirm that there is something wrong with the valve timing or a leaky valve. -
glowing dash indicator lights
Cougar replied to ivantruckman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I agree with you Calebz. For the cost and time it takes to really rebuild a alternator I think you are ahead of the game just getting a rebuilt one that also includes a warranty if something goes wrong. -
Ditto on the ditto for the alternator. -
Heater blower missing speeds replace or repair post
Cougar replied to Skip's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It sounds like the motor is stalled to me. Try disconnecting the blower motor connection and then turn on the power switch. If the problem is within the motor the lights will work normally and not dim now. -
Fan won't blow
Cougar replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The problem may be with the motor but my bet is with the relay. -
looking for the body wiring diagram for an 87 wagon
Cougar replied to subynut's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well, this was the first time I tried to send a PDF file here so I got some training info at least out of it. :-p -
Under the car near the right rear wheel area.
