2
Everything posted by Cougar
You are correct about the source wire having a problem. My info shows a wht/blu wire going to pin 72 on the ECU ties to the valve. EDIT I just read your second post. Looking at my info again it appears we are looking at the circuit backwards. The ECU provides the ground side of the circuit, not the power. The power comes from the main relay, which is behind the left side of the dash, on a yel/red wire. Power to the relay comes from SBF-2 on a red wire to the relay. The yel/red wire also goes to a lot of other places.
Are you saying the input wire is staying at 12 volts when the plug is connected? Just the other two wires are dropping to zero. If this is so then this module is more than a simple switch. EDIT After looking at the drawing again it looks to me that the switch is working as it should be but since there isn't enough details on the modules I can't tell for sure. One thing obvious on pin 3 is, it goes to the fan switch, which ties to ground. So we know that is ok. The AC relay coil gets power from fuse 15 through the evaporation/thermo switch. You should have power from the fuse on pin 3 there. Have you checked that?
I think you are in the right place. My info shows there is 3 wires going to the AC mode control box. There are 2 others for the light in it. The switch is fed 12 volts and it looks to me that the other two contacts may be something like a high/low setting. The power input is a red/blk wire on pin 2. The other two contacts should be tieing to that lead I think so if you don't have 12 volts there then the switch is bad.
I am still wondering about those voltage readings. My info for a Legacy shows the pin for #2 injector goes to pin 13 of the ECU. Number 1 injector goes to pin 4 of the ECU. If you don't mind, would you check the voltage on those pins to ground and see if that is the same? If only some of the voltage is dropping across the injector it could cause a problem in opening. The Noid light may not tell you the whole story here.
Going by the good readings it sounds like you are measuring the voltage on the ECU side of the circuit and to ground. The ECU makes the ground for injector circuit so if you are seeing 5 volts there, then there is either a problem with the external connection to the ECU or the ECU has a internal problem for that injector. Edit: You posted while I was typing my reply. You have a grounding problem to the ECU like I stated above.
I agree with DaveT, this is a air control problem and not electrical. The air vent may be stuck also.
When testing it is best to leave all the plugs in except the one you are working on, unless you want to see if there is a leak between the cylinders. We aren't concerned about that though. By cranking the engine a few seconds you should top out the gauge for a reading. I think you should see somewhere around 165-185 lbs normally but I'm just guessing. All cylinders should be within 10 lbs of each other if things are good.
