2
Everything posted by Cougar
Welcome to the forum Georgiegirl. You have come to the right spot for your Soobie questions. Hopefully you will have lots of good driving with this car. It is hard to say what is causing the light to turn on but some common error codes are with the knock sensor and O2 sensor. There may just be a bad connection to one of the sensors but you don't need to guess. You can have the codes read for free at places like Autozone in the hopes they can sell you a part, though you are not required to purchase anything. Let us know what you find out.
Eric, Checking my wiring info the best I could do to find the location is that it is behind the left side of the dash. It looks like there are a number of other relays there also so it may be hard to tell which is which. The wiring colors for the coil are red/blk and grn/red. The wire to the motor is blk/red and to power red/yel so maybe you can follow the wires to the relay. Another thing that may help is to turn the blower on HIGH and tap on suspected relays with a screwdriver handle to see if the motor will come on then. You may get lucky finding it that way.
I'm not sure if this is still a problem or not since this is an older thread but after looking at some wiring diagrams I noticed there is a diode tied between the parking brake/fluid level and charging indicator lights. The diode is on the low side of each of the lights with the anode tied to the parking light side. I guess if the charge indicator light is not making contact or blown out then a path through the parking light may be made to the alternator circuit. Make sure the charge indicator light is working when you switch the key to ON to test the dash lights.
No, there isn't a seperate fuse for the high setting though after looking at my manual for an '88 model it shows fuses 1 and 2 supply power to the circuit (I never noticed that before). The print shows that the switch makes a ground connection to run the motor so you should be able to just ground the high switch position to check the switch and the motor. If that doesn't work, then the wire to the motor has a bad connection somewhere.
You're welcome.
Check fuse #5 and the red fusible link.
so the bad thing about edis ignition is...
Cougar replied to oddcomp's topic in Old Gen.: 80's GL/DL/XT/Loyales...
While I can't say this for sure but I don't think you hurt the engine. Being easy on it like you were was good to do. With the nice free offers from the members here you should be able to on the road again in short order.
