2
Everything posted by Cougar
If the body of the car is in great shape you might think about shipping the engine to CCREngines and have them rebuild it for you. It will take a good amount of money to have it rebuilt and installed back in the vehicle but you will have an engine with basically zero time on it and with a 36 month warranty.
Looking at the circuit drawing on the link you provided it shows the clutch switch controls a safety relay. If you have that relay the trouble may be with it. You could try bypassing the switch to see if that changes things. If you get no change then the relay would seem to be the problem, as long as other things tying to it are good.
Most of the time these cases turn out to be problems with the safety switches. They interrupt power to the starter solenoid. Another issue that is fairly common when the car gets to around 10 years old is the starter solenoid contacts wear out and you just hear a load click when you try to start the engine. The contacts are closing but due to the high wear on them they don't allow the current to flow to the starter motor windings. Some folks rig up a bypass switch to the solenoid so they bypass the safety switch in order to make the starter respond. It works but you need to be careful with that.
On the Outbacks the crank position sensor is located on the crank sprocket at the front of the engine. I tend to think that your issue may be due a problem with the power to the ignition system possibly. It would be good know if the ignition system is working when this problem happens. Spraying a small amount of starter fluid into the intake might help figure it out. If you get no response from that then the ignition system is suspect. Possibly the ignition relay has a problem.
I'll bet the fuse problem Grossgary found was just due to him not removing the negative battery connection before working on the alternator. The main output lead is always hot to the battery. The main lead most likely got shorted to ground after it was removed from the stud and that blew out the main fuse. The moral of the story here should be always remove the negative battery lead first when working on the alternator and use a test light probe to verify where power is getting to. A very cheap and easy tool to use that can save a lot of time and frustration when looking for electrical troubles.
The knock sensor is a high impedance device. The resistance between the output lead of the sensor and ground should be well over 400k ohms. If you have a 2 pin connector to the sensor it appears pin 1 is tied to ground and pin 2 ties to the sensor output. The sensor output ties to ECU connector B136 pin 4.
The wire from the knock sensor should tie to the ECU, not ground. If you saw zero ohms of resistance to ground on that wire then the wire is shorted to ground somehow. I doubt that is really the case but it could happen. If you are really saying you saw infinite ohms that I would really believe. When you test the sensor wire from end to end then you should see a very low ohm reading. If the wiring is okay then the most likely problem is a faulty sensor. They are known to go bad fairly often.
