2
Everything posted by Cougar
Hi Mike, I assume this engine has SPFI instead of a carburator, is that correct? To see if this is a fuel problem spray a small amount of starter fluid into the intake and see if that helps make the engine run briefly. If you do have SPFI, the injector may be not turning on for some reason. I believe the firing order is correct as you have it.
Tps
Cougar replied to motor275's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The folks here should be able to help you. Jamie has been great to deal with. She visits this site now and then also. I purchased some service manuals through her and she gave me a great deal over my local dealer's full mark up price. http://www.allsubaru.com/html/h_form.html -
Tire Question
Cougar replied to krissy00's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The Michelin HydroEdge seems to have a good review. -
still having cooling problems... im stumped
Cougar replied to misledxcracker's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Another thing to check for if you are smelling coolant is a intake manifold leak. I had to replace the gaskets on my '88 at about 63k miles. The leak was so bad you could hear it with out the aid of a hose. -
I would replace the bad temperature sensor. You will always have to watch the temperature gauge to make sure it doesn't overheat otherwise. If you miss it then there may be needless damage, but it's your car, so you can decide on how you want it. I hope the head gasket is ok also but the test will comfirm what is going on. As far as your Camero goes, I would be sure that the problem is really the ECU. Since they are usually pretty reliable it is the sensors or wiring to the ECU that usually end up being the real problem. They can go bad though. I had to repair the ECU for my '88 Soob once. -
I would think those will be great. Just stay with NGK's whatever you decide upon.
I don't think the car would overheat if the leak was small but it will cause extra pressure in the coolant system. If this vehicle belonged to me I would replace the thermostat with an OEM one along with a new gasket. You shouldn't need any gasket sealer if the surface area for the gasket is clean. I would also remove the constant feed to the cooling fan as it is not really needed if the cooling system is working ok. This just puts extra load on the electrical system. The temperature gauge should read about half scale if things are ok with the system and normal running conditions. -
Have a block check done to see if exhaust gases are getting into the coolant. -
Temp guage reading... Does anyone know?
Cougar replied to Tin Soldier's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The temperature gauge for the digital dash in both of my '88 GL-10's ran in the middle or one line above the middle when things were normal. -
New motor in and running, in a crappy way
Cougar replied to singletrack's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I would think you would have to have the firing order correct and the plug wires connected correctly to get it run at least as good as it is doing. Have you tried pulling a plug wire one at a time to see if you can isolate the tapping, or is it coming from all the cylinders? -
You can either measure the voltage at the sender unit while things are connected and turned on or disconnect the sender and check the resistance of the sender. You may also want to check the wiring going back to the gauge for a problem if the sender tests look good.
There may be a bad power connection to the lock solenoids causing them to not work correctly. Does the system work using the manual lock switch ok? If so, then the problem would seem to be with the remote connection. Alternators can be intermittant so having yours checked would be good. You may want to find out what the stored codes are in the ECU memory and then have them reset to be ready for the next problem.
