2
Everything posted by Cougar
It does sound like the valve timing is off on one side at least. By checking the compression you can see what is happening. The electrical issue is a seperate problem. I suggest you get a wiring diagram for the car so you can check out the places that are tied to the fuse link. I would start with the engine area first since it is the best suspect.
The black link supplies power to a lot of areas including the alternator and the ignition area. Make sure the alternator is not putting out over 14.8 volts DC and check for any AC voltage also.
86 sedan blinker problem... help!
Cougar replied to tonyassparker's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If all the fuses are good then make sure the flasher unit is getting power. -
The trouble may be with the turn signal flasher or the switch.
The throttle position sensor may have dirty contacts.
Thanks for the feedback.
1988 gl wont start about every 25 to 30 starts
Cougar replied to lowbasser's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check the fusible links for a loose connection. They are in the plastic box mounted on the coolant resevoir. Make sure the contacts are snug and clean. I assume the fuse you are talking about is fuse #5 and it has to be installed in order for the ignition to work along with other less important things. If the engine is able to run without that fuse installed then the wiring has been modified. -
Since the lights stay on even while the ignition system is OFF then it sounds to me that the light circuit has been modified from the original design. Normally the power to the lights is cut off with the igintion so even if the ground side of the lights did short to ground before the light switch there would be no power getting to them.
The light switch normally turns on the headlight relays to supply power to the lights by making a ground connection to the relay coil and also provides a ground return for the lights. If your modified wiring is the same way then it looks like you have a wiring going to the light switch that is contacting ground somehow before it gets to the light switch (since you say the lights stay on even with the switch removed). Look for a wire with damaged insulation.
87 GL Wagon wiring issues -- HELP! Please?
Cougar replied to Cptn_Dngr's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The DC return path for the radio should have a good ground connection tied to the chassis of the radio and to the car body, seperate from the antenna. It shouldn't have to use the antenna lead ground to make connection. -
All 4 cylinders full of fuel?
Cougar replied to Mr Whiskey's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have to think the fuel pressure regulator is bad. It would be my first suspect at least. -
83 gl headlight problem
Cougar replied to WheaT_BeeR_MaN's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The light switch makes a ground return for the lights. The trouble may be with the switch. I suspect a bad connection is heating up and causing the trouble. -
Did you puchase a wire harness adapter to go between the existing radio plug and the new radio wiring? If not you need to get one. I think they about 20 dollars. Hopefully you haven't cut the original radio plug off already. Here is some info that may help you also. The constant power may be just green on yours though. Constant 12V+Red/Green Switched 12V+Blue/Yellow Ground Black Illumination Red Doors Left Front (+)Yellow Left Front (-)Blue/Red Right Front (+)White Right Front (-)Blue/Black Left Rear (+)Yellow/White Left Rear (-)Blue/Red Right Rear (+)White/Blue Right Rear (-)Blue/Black -
1991 Loyale intermittent electrical issues
Cougar replied to jbm579's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Welcome to the forum. You have come to the right place for Suby troubles. The alternator definitely had a bad voltage regulator inside it and possibly bad diodes also so you did the right thing there in replacing it. As for the other problem I think you may have a bad fusible link connection which is fairly common. The 4 links are in a small plastic box mounted on the coolant reservoir. Look for a loose connection, especially on the black link. They are color coded to indicate current rating so don't mix them up. Just pull one at a time or write down the order they are in if you pull them all out. If you find a loose connection you will need to clean the connection up and make sure the connection fits snug in the contacts. -
Thanks for the confirmation about the cam drive for the disty 94Loyale. If the belt is broken for that side then just removing the disty cap and watching for rotation while cranking the engine will verify the belt status.
