2
Everything posted by Cougar
I Need some help on my ea82t 86 Gl-10
Cougar replied to 86deathwagon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You may have some bad intake manifold gaskets that are leaking coolant into the intake. Check them for air leaks also. -
Conversion charts are easily found using a web search. 1 pint is equal to 16 fluid ozs. and also equal to 473ml. A quart is equal to 2 pints so that equals 946 ml. Since you only have 1 can I suggest you use what you have. It may take a little longer to work but I would think it will still do the job.
Dies out
Cougar replied to woosha's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
To verify the coolant sensor is the trouble you could watch the voltage change while you monitor it with a voltmeter at the connection to the ECU. This very well could be the trouble. Other things to check are the TPS and MAF sensors. -
Need electrical help - ignition
Cougar replied to mcdanielsamuel's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Opps! You're right Gloyale and good catch. I was thinking of EA82 systems. -
SPFI "cold" weather won't start - now running
Cougar replied to msteel's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I doubt that the coil is bad. You stated you think you have a short from the primary side of the coil. Is that to the minus side of the coil or ground? A better check is to see if you have voltage getting to the minus side of the coil with the ignition ON. If that is ok then check to see if you have pulses getting to the minus side of the coil while cranking the engine using a test light probe with the clip lead tied to ground. You most likely will see a steady light indicating that the CAS in the disty is bad or the ignition amp is bad. Since this trouble seems to be intermittent there may be a bad connection in those areas causing the trouble. -
Try spraying some starter fluid into the intake the next time the trouble happens. If the trouble is with the fuel system it will start and run briefly. If you get no action from the engine then suspect the ignition system for the trouble. -
Even though the voltage is low going to the coil you should still get spark. The voltage should be close to whatever the battery voltage is at the time. If it is lower then it may mean there is a bad connection somewhere but there still should be spark. Make sure fuse 5 is good, the horn should work if it is ok. The other possible troubles are the CAS in the disty and the ignitor module. -
The regulator is built into the alternator. I don't know why their information is stating that is isn't built in. The warning lights are part of the exciter circuit of the alternator so they can be tested when the key is turned to ON. Even though the test stated the alternator is ok it has an intermittent problem and it needs to be replaced. The brushes may be going out on it.
I take it that the blower isn't working at any speed. Which may mean the thermo protector in the resistor block may be open. When some of the speeds don't work it is usually due to open resistor coils. Either way the block needs to be replaced. Another possible area of trouble is the blower relay. By using a test light probe to check for power at the blower you can see if the relay is working or not. If you do have power then the relay is ok and the resistor pack is most likely bad. You can also apply power directly to the motor to see if it is bad.
You can do that alright but you defeat the safety feature by doing that. If you have a bad accident some serious things could result. Something to consider at least.
Instrument Panel Light Help
Cougar replied to 88 EA82T's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I think these will work for you. You will need to push the wire leads out of the holes on the old ones to replace them but not a bid deal. A box of 10ea. is about 9 dollars. They have a minimum order amount I think. http://www.newark.com/spc-technology/2182/incandescent-lamp/dp/50N8118?Ntt=50n8118 -
Did you check the fusible links in the box mounted on the coolant reservoir also?
The wire connection is just that, a connection. That means you can connect it any way you want to just as long as the wire connection is good. Which means there is no added resistance to the circuit at the slice point. The circuit is a pretty high resistance circuit anyways so even if the splice added a little resistance somehow it wouldn't make a difference.
Fried Alternator wit smoked Radio
Cougar replied to Buddy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I think you are making a wise decision based on what you told us has happened already. May this year be without any break downs. -
We have told you several times that the alternator is shot but you don't seem to believe the advice. The shop didn't test for AC voltage appearently. Go ahead and put it back in and see what happens. -
Hopefully the bad alternator didn't damage the battery too badly also. If the battery doesn't take a good charge you are going to have to replace it also. -
Are these alternators just crap?
Cougar replied to Speedwagon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Your alternator is bad, replace it. -
Yes, I know. I was responding to your question about what happened. Hopefully the only thing that was damaged was the radio.
