Everything posted by Suzam
help
Suzam replied to alleos's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Welcome to the board. Now that you have joined, you can use the search function to find a lot on info. Try using keywords on you question. With a little research chances are you'll find the answers. -
Is your co-worker (the auto mechanic) employed as one currently? How much money is waste? You already bought it. For piece of mind and preventative maintenance, I change all of the fluids on a regular basis. I change out rear diff and front transfer oils between 80 & 100K in my auto Subies. If nothing else a cleaner, correct viscosity oil has less drag on the drive train than oil with dirt and metal suspended in it and lubricates better. Maybe it is a waste but I'm happier after it's done.
Without the hood the aerodynamics change and you might see less MPG, but I don't think you'd have a problem as long as the weather is cold, the hood plays a big part in forcing air in and across the radiator and engine. Are you sure it won't fit in the back of your wagon? Wrap it in a thick moving blanket and slide it in on an angel and (without me measuring it) I think you'd have a chance on getting it inside. Seems like a bit of work to remove, replace, remove and put original back on. Plus hood alignment is a pain sometimes, getting the hinges and front catch to match up. Strapping on top seems to be the best if it won't fit inside. It might be illegal not to have a hood on but if you drove at night who would see it? "But officer, I swear it was there when I started my trip!":lol:
10 MPG Outback
Suzam replied to nicolo69's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
That should throw out a CEL. Does the CEL light up when you first turn the key to start? If not maybe your CEL bulb is out. -
If you're handy and have a LOT of time, the whole assembly is accessed from above the headliner. This has been covered on the board, with a little searching you may find the procedure. The whole window unit needs to come out and takes several hours to remove. If you're lucky you might find a replacement in a junk yard, but it would need to be removed also, but that would be good practice for yours. Otherwise caulk the front one and see if you can realign the back one and go from there, although the rear rails might have snapped the screws that keep them aligned which is a headache. You can drop the headliner and take a look. You could always talk to a dealer and see but a 10 year old car with addition problems to the unit might not be covered. It doesn't hurt to try.
Tire Howl
Suzam replied to Buick350X's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Oh no! Are you trying to tell us you are running mismatched tires? -
MPG issue
Suzam replied to brysawn's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
The sending units inside your gas tank are dirty and giving false readings. A common problem. If you search for "sending unit" you'll find out more about it an ways to make them read better. Rather that saying it only goes 250 miles before the light is on can you tell us how many gallons of gas are used in those 250 miles? That's the way to accurately get MPG. MPG = distance divided by gallons used, not distance per gas gauge reading. -
I had a similar problem in my daughter's 97 2.2, stone cold lower hose but I think she had heat... I can't remember and it wasn't cold weather at the time. Temp rose and fell while driving, not a lot but maybe between 1/2 and 5/8 of the way up and never overheated. New T-Stat and a correct burp fixed the problem. After 2 years the temp stays steady and NEVER deviates from the 1/2 mark. Has the T-Stat in yours been changed or is it new from the engine swap? The reason I ask is it would be unusual (but not unheard of) to have 2 in a row bad but the one from the swap could be bad from the beginning.
