Everything posted by Suzam
Ok so you have the switch and the plug that goes to it and then just the cut wires? The original wire harness had additional connectors on it, the one I was talking about is a plug that fits on the OEM relay. It has connections to tell it when the headlights are on low or high so they only work when to low beams are on.
The was a Verizon building I would park next to occasionally that was an old telephone switching building. Whatever they had inside would not allow me to use the remote until I was almost touching the hood of my car. Interference RF can most definitely create a dampening field. You should research the area and see if you could at least track down a source, and let us know what you find.
WELCOME TO THE BOARD! Have you tried tire rotation to see if it helps or changes the problem? Warped rotors can cause vibration and shaking also. Does it vibrate when the brakes are applied? Also a weak front strut could cause a problem with a slightly out of balance tire. You didn't note the mileage, but it could be a badly worn steering parts as diagnosed.
You need to remove the entire panel because the switches are attached from the back. There are screws in the armrest and in the recess behind the handle that are behind plug covers. Then carefully pop the fasteners at the bottom and open side on the door. Then slowly pull away from the bottom of the door frame. Then slide it off the inside door handle and lift straight up. It is kind of hanging on a lip at the top of the panel at the bottom of the window opening. Be careful not to pull too aggressively on the panel because you can pull the fasteners out of the panel, you want them to stay attached to it and not stay in the door, so try to pull near each one and don't just yank the panel. Also be mindful of the wiring for the switches, there is a little bit of length in the wire to the plug so you can reach in and disconnect it.
Wow 21.2 MPG
Suzam replied to jensen0510's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
@jenson0510 that's pretty good for a high mileage Subie! 21mpg for short "cold engine" trips is about right. I have a 97 2.2 that gets around 23 and a 01 2.5 that gets 21 if we drive it around town. If we go father they both jump up to 23-25. Highway gets better than that 2.5 = 28mpg & 2.2 = 30mpg. If we go on looooong trips (400-500 mile in one shot) 2.5 = 29-30 & 2.2 jumps to 32+mpg. -
I would ask the dealer to supply the proper master key for your car unless they told you up front it would be extra. They should make good on it or at least give it to you at a substantial discount. Doesn't hurt to ask. Gently remind them you'll be back for maintenance and mechanical repairs. They make money on those things.
15 in rims?
Suzam replied to rangermatt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
No, 15 inch wheels will not clear the brake calipers. You can use any 16 inch wheels from an Outback, GT, WRX or you could look for some steel wheels of they are for "go" and not "show". Oh yeah, WELCOME TO THE BOARD!!!! -
Most alignments per se aren't dependant on the tires as much as the wheels themselves. Having said that I would want the setup to be as close to what it will be after the alignment. Rotation balancing and/or new tires install should be done first then the alignment. I have a deal at a tire center near me that offers, for a price, unlimited alignments and rotation during a specific period of time 1, 2 or 4 years. I usually get it done at least every year after winter, but if I feel I've hit a curb or pothole I'd do it earlier. The printout from the computer after alignment has almost always said I was still in spec with minor tweeks so I guess I am overkilling it a bit. However it would depend on the conditions you are experiencing in your driving area. Off roading would warrant more alignments.
lsd problems
Suzam replied to Fordman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
That's what happens when a post over a year old gets resurrected.
