Everything posted by Suzam
+1 on the rotors, I have the same issue with a MY02 Outback. This will be the 2nd set if rotors and I'm going to put these on myself when the weather breaks (get cooler). Front rotors vibrate the steering wheel, rear rotors you feel in the seat of your pants. There are two reasons they do this: one is warpage, the second is a build up of brake materials from the pads on the rotor surface. You can try having them trued by a shop if they have enough thickness, but if it warped, I would just replace them.
Press and depress are the same as far as I'm concerned. The front signal has 2 bulbs, 1 double and 1 single filament if I recall without looking. The double is on dim filament with lights and both flash for the turn-signal. Turn on the 4-way emergency flashers and compare the left and right to see if there is any difference. Maybe a visual comparison will reveal a problem. Does the rapid flash happen with the regular lights on and off or is there a difference in speed when you have them on or off? If all else fails, buy some replacement bulbs and swap them all out.
Welcome to the board. Plenty of information here about what you are experiencing. You can use the search function for a limited look around for answers, also check the "Similar Threads" section on the lower part of this thread. With that mileage you may want to consider a used 2.2 swap to eliminate head gasket issues the 2.5 has and not worry about a rebuild. Otherwise if the engine is in good shape, new head gaskets would give you a new lease on life, but the lower end would still have 163k. There are several ways you could go on this, do some research here and see what makes the most sense to you and your situation.
oldbluesfan, I would try to reset the entire system this way: Disconnect the battery's positive cable and wait for a few minutes. Then turn the key in the ignition all the way "on" as if the car is running. Reconnect the battery while the key is still in the "on" position. Then start your car by turning the key forward to fire up the starter. This should reset your alarm to factory specs. This is also the way to keep your alarm from going off after a battery disconnect if you don't have the remote available to quiet it. In order to turn the horn alert on or off just hold BOTH the lock and unlock buttons at the same time until the horn sounds. Valet is set as you described, just hold the unlock button down with the driver door open for at least 2 seconds until the security light flashes quickly. ****These instructions are for the MY2000+ alarms, this is what I do for my 2001 model. Our MY97 and 98 are different for valet but the same for the battery disconnect resetting procedure.***
Even if you do treat the smell, if the cause is still there you'll never get rid of it. The first thing is to locate the source of the smell and the cause of the problem. Moisture is usually a good cause, windows open during rain or bad gasket seals on windows and doors. Other tings are items like food rolling under seats and left there to let nature take its course upon. Leaking heater cores are know to drip coolant into the cabin as well. A good clean out of the interior will make sure there is no trash and also give you a chance to check for wet spots. Try parking in the sun with the windows down and see if that helps.
Yes there should be a relay in the cabin above your left foot under the dash attached to the side of a gray wire junction box. It's about as round as a quarter and maybe 1.5" long if my memory serves. Also check the main wire that passes through the firewall. It has a plug up around the brake pedal arm under the dash, possible it has come loose. There is also wires that go to other wires in that junction that attach with vampire clips so it knows when power is to the low beams and high beams and throws the relay accordingly. I've installed a couple of light sets in a 95 and a 97. If you need a wiring schematic let me know and I'll see if I can dig one up. I'd consider a change out or testing at least one of the bulbs before sticking your head up under the dash.
Double check the fluid level, those are sometimes symptoms of low levels. Especially the Cluck when turning. The fluid sloshes away from the bottom of the pan and the pump looses pressure because there isn't enough fluid to be picked up. Check it hot on a level area with the engine running and run it though all the gears first pausing for a couple of seconds in 1st, 2nd, 3rd D and R while applying the brakes. This fills the valve body in all the nooks and crannies.
Our 2001 Outback 2.5 gets 20 to 21 MPG Local and 26-28 MPG highway. Our 1998 Outback 2.5 gets 18-20 local and 24-26 highway. Our 1997 Legacy 2.2 gets 22-23 local and 29-31 highway I get at least 2 MPG more than the wife in the same car at any given time. Driving habits make a big difference. They are all automatics the 97 2.2 has synthetic trans and differential oil. All run reg engine oil.
I agree, but a finicky thermostat might cause a similar problem. If wrongturninwv wants to do an exhaust gas test of the coolant to confirm a bad headgasket. I was suggesting an inexpensive T-stat replacement before resigning to a blown headgasket since he has had it happen every time he drives 3 to 4 hours. If the radiator cap is loosened on a hot engine, the coolant will flow into the overflow tank from natural expansion. wrongturninwv: is the temp gauge steady until the overheating and then pegs the meter or is there a fluctuation in the needle?
I didn't see any mention of a new thermostat. Replace the t-stat with a genuine Subaru one from the dealer, refill and burp the system, topping off the overflow tank to correct level. If it still overheats then suspect an internal headgasket leak. Search this forum for plenty of info on HG leaks. Did I mention it should be a GENUINE Subaru T-stat, aftermarkets do not work well in Subarus. FYI: internal headgasket leaks do not produce "smoke" out the tailpipe. Hot compression gases are forced into the cooling system which creates air pockets in the water jacket that stop coolant flow and cause overheating.
