Everything posted by Suzam
Yeah my handle seems to spring back to home also, but I still need to push it, it doesn't so much move it any more as set the internal linkage to the proper position. I don't always have to do it either maybe 40-50% but I'm used to it so I do out of habit. Did you at least try to push it from the back to see if it works or did you just squeeze and let go?
For now I would ignore the O2 sensor codes. I would disconnect the battery to reset the ECU since you now have all codes read. Drive another car to the dealer and buy a Coolant Temperature Sensor, go back to the car and replace it, then reconnect the battery and see if you still have the hesitation problem. This is the easiest (cheapest) way to start eliminating any possible problem and in my opinion the best place to start. Just my 2 cents.
lsd problems
Suzam replied to Fordman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
What's the year, model and mileage of the car? -
Reprogram of ECM
Suzam replied to Roamer's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
It's possible that the O2 sensor needs replacement at 123k but they usually throw a CEL if they are that bad. I had one that would clear its CEL after a day or so and not show up again for months. The car ran fine and unless your MPG has dropped it's most likely still functioning. Don't know about the ECU, but like Josh just said, $20 for a CTS and a couple of minutes with a wrench may cure all you symptoms. -
Did you ever change the t-stat? Since it really hasn't "overheated" per sey and only gone up about 3/4 on the gauge then my money is still on the t-stat. An OEM should solve your problem. I had the same symptoms on a MY97 2.2 with the aftermarket in it. Idled fine and ran locally ok with a needle width below 1/2, but would creep up on the highway to 3/4 then move around a little then back down again. After a drive check your lower radiator hose, bet you find it's stone cold, or at least a lot cooler than the top one. That's what happened to mine until I replaced the t-stat.
Help. please
Suzam replied to DeSubiefan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Yeah that's a bit high with mechanical issues. I bought a 97 Legacy with a 2.2 and 116k for $3600 and I only paid that much because the car was in what I considered excellent shape. It was well taken care of and I only had to do the 120k maintenance. -
OK Nipper, I challenge that statement. Why would the fuel be warmer than the air in the tank? The ambient temperature should keep both relatively the same give or take. Besides underground tank fuel is around 54° for the most part, so your light would go off in warmer weather if you fill up with cooler fuel? I know you quantified your explanation with the "I think" sooooo, please enlighten us, oh great purveyor of knowledge.
I used the Chevron's Techron gas additive to help with a lazy gas needle so it may help with the warning light too, although I don't recall ever hearing of one coming on as early as yours. Pick a couple of bottles up at Walmart or Pep Boys. It would be worth a try for a few tanks. Beats starting to pull things apart.
Keep it running, some of what you mention is scheduled maintenance like timing belts etc. If you get another car you'd be looking at repeat cycle of same costs for maintenance again. And possibly replacement of similar parts. You already decided that the car was worth the investment when you did those repairs. If you trust the car in its current condition, I'd drive it until it gives you a real repair bill that exceeds the total value or at a point where you feel it is no longer reliable transportation.
If it's a 97 I think you have square cutouts in the bumper cover? This style was on the 95-97 MY after that they were the oblong ones. Round lights will not fit but ebay sometimes has the sqaure fog light like these shown and there are DM projector ones fit also. I lucked out and found a NIB set on ebay for our M97 wagon that came complete with wires, switch and relays for $50. It came with the stock brackets too. That made the install simple, took me about 1 hour to install. Adjusting was a pain because I set them them higher than they should be and had to adjust the aim a couple of times (too low and you reflect off wet pavement).
