Everything posted by Suzam
Might be loose, because it shouldn't leak. If you want to tighten it be careful! It's designed to snap at the head if over tightened. It's only a plastic piece after all. If you wait until the engine is cooled down, park the car nose up if possible then back it out and make sure there isn't any dirt where the flat washer comes in contact with the radiator. Then tighten it snug but don't over tighten it (I speak from experience).
I had a 95 L series with 160k and no major problems, until an accident forced retirement. I was aiming on 200k before I was considering replacing it. What to look for is tourque binding and mismatched tires. Make sure the is NO fuse in the FWD socket under the hood. Check for the usual fluid leaks underneath. 120k service which includes a timing belt is due. There will most likely be some cam seals leaking too.
Rip
Suzam replied to LosDiosDeVerde86's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Adiós mi amigo. La velocidad de Dios. -
Trailer Towing
Suzam replied to Phillip's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Does anyone know if the reason North American vs. other countries in towing capacity rating difference is most likely from national and federal requirements and mandates? The physical construction of the basic Subaru framework and undercarriage should be the same, I would think, no matter if it's build in the US or Japan. So I'm guessing it's a NHTSA thing as far as how much gross weight with or without trailer braking? I tow a utility trailer rated at 995 lbs. every so often and I know I've had over 1,000 lbs in it and the handling changes greatly with more gross weight. -
I feel your pain... My daughter was in downtown Philly about 5-6 years ago and left her portable CD player (remember those?) on the console. Some smack-head broke the trianglular opera glass out on the rear quarter panel of our MY95 Legacy only to find out he couldn't reach the inside handle. Being the genius that he was, he just blasted out the passenger side window. Stolen walkman cd player & loose change = $25 2 pieces of glass replacement = $240 (+ time) Final cost of portable cd player = $265 (+ time)
Thanks for the answers so far. grossgary, What is the "stopper" exactly? I see a pair of what I'd call guides at the top of the inner and outter doorframe, the outer ones have a clothlike patch on them and the inner ones look like white plastic. They oppose each other with the glass in between. The inner ones have bolt adjustments to make them closer/farther from the glass. Are these what you're calling a stop? Or are the stops inside the door itself and if so do they travel with the glass and it's slides or are the stationary? I could take the panel off again and take some pics if I have to.
MY97 Legacy, the power window functions fine except at the end of traveling up it sort of shifts out a bit at the bottom makes a clunk noise and goes 1/4" past the front triangular seal (it's actually split the top a bit). I took off the door panel but didn't notice anything out of place (I'm no expert), the inner and outer guide pads seem to be in place but I noticed that on the outside of the glass there is a 1/2" wide faint scratch along the height of the window that aligns with the rear guides. Any ideas if this an adjustment problem?
Yeah, if the seller (private?) has the maintainence records they are worth their weight in gold. You'd know all the things that were done to the car. Eliminates guesswork and services that you do because you didn't have proof it was done prior to purchase. Check it for torque bind symptoms too (do a search on the board). It it is in exceptional shape then that's not a bad price. Sometimes if you wave $4600 to $4750 under the sellers nose, they bite on it.
If you move the day/night lever to half way between does it tighten up? If it does you can remove the mirror form the windsheild and open up the back of the mirror and tighten the fork type thing that presses on the ball joint (2 screws). I've done it to a couple of them. One held fast, the other I have to redo about every 2 years.
