Everything posted by Suzam
Just so you know first off, no one was hurt. The young one borrowed the car for the weekend and was in the city last night when another car ran in front of her at the intersection. 2 air bags later... (see attachments, if they worked) The radiator was pushed against the engine which itself seem to be pushed back. Nobody hit the windshield, the passenger side airbag did that damage plus k/o'ed the rear view mirror. I guess we know that 12+ year old airbags still deploy. Unfortunatly at 160,000 miles I think we're done.
Is this a dealer or private sale. Private sale could mean all receipts available for a history which is worth it's weight in gold. Otherwise, check for tourque bind by driving in a tight circle clockwise and counterclockwise and make sure there is no fuse in the FWD socket under the hood and dirty or discolored antifreeze fluid in the radiator overflow bottle for indication of a blown headgasket are 2 that come to mind right away.
I had the passenger side one melt on our MY95 Legacy L. I think the blade of the bulb slid blow the "C" shaped plug and had contact only on the outer edges causing resistance heat. I replaced the whole plug with this aftermarket plug. A NOKYA model NOK9101 plug, you can google for a retailer. Just remember to slide the rubber boot over the new wires before splicing, I didn't and ended up splitting the boot while I tried to stretch it over the splice.
Sounds like it could be classic blown headgasket. Do a search of this board, plenty of info. If the used car dealership does a hydrocarbon test on the coolant and it's positive, maybe you have a chance of getting them to repair it under thier warranty. Get it diagnosed ASAP. I f you don't trust them have the Subaru dealership do it for you and have them pay for a positive test. Hopefully the engine hasn't overheated to the point of warping the heads, which is fixable, or cracking the block.
Check the torque of the lug nuts. Over tightening can cause stress on the rotors. After a while the heating and cooling cycle can causes the rotor to warp. Also aftermarket pads can leave a residue on rotors, light sanding of the rotor might help if that is the cause of vibration. In my experience, a very noticable shake of the steering wheel is the front rotors. A milder shake and more shimmy of the car is the rears. Once you experience both it's a little easier to ID.
Make sure your headlamp plugs are in good shape too and making good contact, it's the top one for the low beam. I went through a series of bulbs, and went to other suppliers after the ones I got at Pep Boys kept blowing out. If they are mistreated being shipped to the store or packaged poorly, it only takes a few good bangs of the box they are in to shorten the life. Don't forget to be careful to keep your fingers off them. Oil from your skin shortens the life also.
My 95 stock fog lights have a 2 hole bracket that bolts to the metal frame under the bumper cover. There are 2 threaded holes above the opening that face downward, these should also be on yours. The holes are forward of the lenses so the bracket extends forward like a "7" with the light at the tail of the bracket. http://www.geocities.com/ss_aruba/golf_shots/LilBlueFrt.jpg
