Everything posted by Suzam
Question????
Suzam replied to cutoffman's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I wonder if a change in the AWD clutches or engagement from older to newer models delays or reduces the chances of torque bind over the life of the car???? -
Question????
Our MY95 Legacy always seem to have "tighter" AWD than our MY01 Outback Ltd. I find myself using 1 & 2 to get the 50/50 more in the '01 for less front wheel slippage than in the '95. -
I agree with Josh, You didn't say how long you've owned this car or what year it is, so how many miles you put on the car per year could make your mind up for you. CCR is a great place for a replacment motor, and I don't want to take away business from them :-\... but if you only put 12 to 15k per year on it, there is no reason not to expect another 6-8 years and around 200k out of the original engine. If you stay with the original, don't forget the timing belt, if it wasn't done already.
Hey Cookie, which size tires did you get? I bought the trailer that folds in half from harbor freight about 3 years ago. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=42709 I got the 8" wheel version because I trailer locally and didn't expect any long trips. I've use it about 20 or so times but only a couple at capacity. Worked very well on the back of my 01 Outback Ltd. and figure it's paid for itself and the hitch.
My dilema....
Suzam replied to dome24's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Silly question but how much gas is in the tank? Any chance the fuel pickup is now above the gas level? You did say you were on a pretty good tilt. -
105K for a timing belt. http://www.cars101.com/subaru/subaru_maintenance.html raven05649 is correct, it should run you about $600-700 with water pump. While the mechanic is there have them check the oil pump and front oils seals. Much cheaper to have them serviced now than later. You might also want the headgaskets checked for external leaks. If the car was treated with the coolant additive, it was covered by SOA to 100K. You would be out of the coverage, buy if it is evidence of leakage you might want to have a dealership look at it.
I Agree with Nipper. I have a MY95 Legacy that throws that code every 6-12 months. If I reset it, I can go for another 6-12 months before the CEL comes back on. No difference in performance or gas milage, however it has over 150K miles on it, so I guess I could replace the O2 sensor........ **Yawn**....... just too lazy. zzz
