Everything posted by Suzam
It took me 5 days and a couple of posts here before I found where to connect the harness. The MY01 models have it all the way in the back compartment I figure the MY00 should be there too. Pick up the rear floor to expose the spare; on the right (passenger) side, there is a carpet panel on the floor with a syrofoam type spacer below it. Remove these, and then fish in the body frame openings along the outer body to find the plug. It should be close to the center of the opening.
Does it spit it out on it's own without you touching any buttons? I remember hitting the #1 button thinking I was loading additional disks and was ejecting the disk in slot #1. Have you tried selecting an different slot? Try pushing say..#4, you should hear the mechanisum wind up the slot for you to insert the disk. Afterwards it winds back down and you can select another button/slot for another disk.
A compression test will not be a positive test for a blown headgasket. The Phase I 2.5 can have a good compression test with a bad head gasket. That's why the overheating can seem to be an intermittent problem, like at highway speeds but fine at idle. Unless you see sludge in the overflow and it smells like exhaust, you can only tell with a hydrocarbon test of the coolant which will tell you if there is a leaking head gasket. As I read your post I wonder if you have tried replacing the radiator cap with a new one?
Outback hotness....
Suzam replied to WJM's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Sweet! I like that drop and with those wheels and tires I bet it does track nicely.:burnout: -
I agree with OB99W, a couple of years ago I put WRX wheels on the Legacy and asked around about a good tire pressure. I wanted to run them a little higher than stock, and a lot of responses were to inflate to maximum pressure stated on the sidewall. I can't belive that there are that many drivers running that kind of pressure without failures. A blowout at any speed could be a disaster, but at higher presure the odds are increased for failure dramaticaly. There must be a write up somewhere on the internet about the danger of this.
iomatic, Have you had a chance to brave the cold yet? The other connections I think you were asking me about are on the opposite side of the engine in the same basic place. I just tightened the clamps on either side of the rubber fuel line that connects the metal lines together. There are 4 hose clamps altogether-2 for each side. As mentioned by Juan, the reason you smell it more when defrosting is that it blows directly into your face. You just have to figure out if it's gasoline or antifreeze. Mine smelled of gasoline, just like when you fill the tank. Antifreeze has more of a sweet rubbery like smell. Just remember-don't over tighten any clamps, just snug them up and recheck later. Or even better, if you locate the problem you could get a mechanic to service it.
