Everything posted by Suzam
Ok maybe I was a little confusing on my first post. The way I read your response it sounds like you checked in front of the rear seats? The MY01 models have it all the way in the back compartment. After picking up the rear floor to expose the spare, on the right side there is a carpet panel on the floor with a syrofoam type spacer below it. I had to remove these, and then fish in the body frame openings along the outer body to find the plug. Believe me, it took me 5 days and a couple of posts here before I found mine. Hope this helps.
Before you start tearing things apart, check your license plate. I had an annoying rattle from the rear that I actually had back to the dealer because I was convinced it was up above the roof liner. It was still there after the dealer checked it out. I got on my back in the rear of the wagon and rapped on the roof and could get it to vibrate but still couldn't track it down. Finally my wife, who was watching me from outside the car, tracked it down to the plate. I removed the dealer's frame and now it's quiet.
Tom, I sent you an email...I found the receipt: SUB45124AC000 is for the "Air Plug" SUB45128KA000 is for the "O-Ring" $8.20 & $1.84 respectively. Not sure why 2 part numbers, they were both in the same poly bag. Edit: I Googled the number, sans the SUB (45124AC000), and got a couple of hits including http://www.1stsubaruparts.com/oe_list.html and one in Russia.
Do the stations change on the display, as if the radio itself, still works? I'm pretty sure as I remember, that there are at least 2 sets of plugs on the back of the radio. One supplies power the other is the plug that has all the speaker wires connected. I suppose it's possible that the speaker plug has somehow popped out, if you can get to the back of the radio to check, I'd do that first. If all else fails ebay should have a stock one for a little bit of $. Good luck.
Strictly speaking the manual with the transfer of a 50/50 split front to back at all times will be better for least traction situations like ice, mud, loose dirt, etc. Some drivers think the auto with a 90/10 split until slippage is better on dry and wet pavements as far as drivability day to day. The automatics "lock" the center differential at 50/50 in 1st and reverse gears for better traction. I agree with friendly_jacek...limited-slip differentials (LSD) in the rear make a BIG difference compared to the open diffs.
Nope – sorry, but I tossed the old part and bag. I don't think I kept the receipt since I just walked in and paid cash. It was in the database of the parts department, I remember because I didn't drive the car there and the guy said he needed the VIN, but since I didn't have it he just went by the model and year. Took him about 5 minutes but he found the number and had it in stock. I can't belive you'd need to get an entire radiator, if that were true the service departments would be replacing a lot of radiators. The part breaks off very easy, mine was weeping and I just tightened it less than an eighth of a turn and snapped the head off. I was lucky that there was enough of the slots left on the threaded stud part for me to back it out. I would also think that a radiator service place might be a source if the dealer insists that it isn't available. :-\
break-in
Suzam replied to grady's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Until the internals of the engine get settled into themselves I would read the manual and follow it for break-in recommendations. -
Our MY01 Wagon did the same thing. I believe there are mounts below the gasket at the bottom that the windshield rests on. Our dealer said the same thing, rock strike. It would be nearly impossible for a rock to have hit under the wiper. Our crack started to head to the right from the driver's side, within 2 weeks a second crack on the passenger side started and it too went to the right, away from the driver's side crack. Eventually the driver's side caught up to the passenger side and formed a double arch, one long arch to the passenger side then another smaller one from the passenger’s side over. Dealer refused to budge even with the additional crack, so the cost of the new replacement was my contribution. I had posted here about this and I remember at least one if not two similar problems from others. BTW- our Limited OB has the winter package with the heated base. $380 to replace with an aftermarket. The heating element looks different but performs the same.
Did anything unusual happen prior to the problem? Anyone under the hood before, to do work or check oil, etc.? Driving in a lot of snow or rain recently? When it first starts and runs, is it smooth RPM or stumbling before it quits? Could be any number of things from a loose connection of a hose or wire under the hood to a clogged fuel filter or just a dirty air filter.
If the ignition was in the ON position with or without the engine running the fuse in the FWD slot would work. I seriously doubt that a tow truck driver would do that. If anything had he realized it was a Subaru AWD he would refuse to tow it and call for a flatbed. I think I'd call the tow company now and let them know to expect to cover any damage to the AWD after the dealer inspects it. Subaru is very clear about not towing the automatics in any fashion, always flatbed.
If it's like the Outback's set up, there should be a black boot covering the back of the bulb housing with a plug going into the back. The plug should pull straight off, then you peel back the boot to expose the back of the bulb. You should see a metal clip that you unhook and swing away from the bulb. now the bulb should be free to remove. Do forget to keep your fingers off of the new bulb. Any fingerprints or other oils can shorten the life of the bulb. If you do touch it, wipe it off with a lint free cloth and isopropyl alcohol. Good Luck!
I know that the on our 01MY Outback the LSD was only available and was a standard option on the Limited, LLBean and VDC models. Base model Outbacks didn't offer it, even as an option. I think that holds true for the 00-04MY. The LSD might have been offered later in this body style as an option on the regular models but I'm not sure.
