Everything posted by Suzam
Ok I have totally lost the owner’s manual for our 95 MY Legacy with AWD. Can someone give me the correct capacity of the fuel tank? (Please-no guess or comparisons to other models.) I’d like the numbers straight from the book, since I have the gas gauge symptoms that won’t give me a correct reading, I really need an actual capacity. I’ve been filling it up about every 200-250 miles but it will rarely take more than 10 US gallons (24-25 MPG average all around). I’d like to be sure I can go to 300+ before a fill up but don’t want to run it dry testing the total fill point. :-\
To stop the "honk" on our MY01 I just hold BOTH remote buttons down at the same time until it gives a signal then it's quiet until I do it again. I keep mine off until it goes to the dealer for service. The techs walk around pushing the button until they hear the horn and find the car. If I forget and I am waiting for a quick service stop, they sometimes come back in and ask where the car is parked.
Do a search for "rear differential" you'll see some discussions on changing the oil. Seems as if your drive extention of your socket wrench should work fine for the rear, not sure about the front though. Also a good recommendation for the rear is to lossen and remove the top plug first...wouldn't want to drain the oil out from the bottom, only to find the top stuck tight and no way to replace the empty differential.:boohoo:
Hitting a deer at 35 MPH is dangerous. You hit them at a height that they come over the hood right into the windshield. They are of a weight that can cause a lot of damage. I would try to avoid one by at least not hitting it straight on. A glancing hit off a fender it time allows would be preferable. I have always used the rule that if you are heading for an animal give it a chance by braking hard but never swerve. A dog, cat, squirrel, chipmunk or whatever isn't worth hitting a tree, car or other harder objects and risking injury to yourself or passengers. If the animal makes it by you braking it's lucky. If not you’re lucky. At least somebody wins in that situation. Your 16 year old is very lucky it wasn't worse than it turned out. Hope your car gets fixed right when it's all said and done.
this test. Open your hood while the engine is running and stand on the brakes while slowly revving up the engine in drive and then try it in reverse. A bad mount would let the engine torque up off the seated position. I've done this with a V-8 and watched it look as if it would jump out of the engine compartment because the mount was totally broken in half!
tire pressure
Suzam replied to monk50's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I have found that 2-3 lbs over recommended pressure works well for me. I put 90 miles per day at mostly 65-70+MPH on the highway with the same setup as you have. Over 10k on the tires and wear is very even. -
Buying a Legacy
Suzam replied to anw's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Hi and welcome. If you are looking at a 2.2L and NOT a 2.5L, I'd say it's a reasonably good purchase. The oil leak should be minor if it originates in the front of the engine. Possibly a cam seal, oil pump seal or oil pump screw retightening. Not overly expensive to fix but you need to find out about the past maintenance if possible. If the timing belt was changed at every 60 miles as it should have been, your looking at a replacement in the next 15K, but if the mechanic is already in the front end you might as well have them replace the timing belt and install a new water pump. If it's an automatic make sure it doesn’t have torque bind in the AWD system, test drive it by turning in as tight a circle as the car can going both left and right. There should be no resistance or an alternating tight/loose feeling while the wheels are rolling. Do a search of the board for more info on this problem because it can also be caused by low tire pressure or mismatched diameter tires. Get your mechanic to give it a good going over, there are plenty of board members with well over 200k and still going strong! -
Go to the link in my last message, search through the site for the harness, you can buy it separately. It plugs into an adapter plug on the passenger side under the floor insert towards the rear, near the gas filler tube. No splicing required. As far as the bolts, yeah they are a little tough, they supply a wire that threads onto the bolt, You fish the wire through a hole big enough to fit the whole blot and an oblong washer into and carefully pull it into position in the bolt hole. You'll need to do this for both sides.
Hey Carl, I put a Hidden Hitch and wire harness on our MY01 OBW. Never a problem with the electrical hookup. Took me less than 1 hour to do the job. The tricky part is fishing the bolts through the frame. Check it out here, http://www.hitchesonline.com/subaru_cl2_outback01.htm I looked at the link again and that isn't the hitch pictured on that page. It's a bracket that gets bolted underneath on the frame.
I put a set on our MY95 Legacy L. They are great--improved handling and they feel tighter than stock size when driving. Absolutely NO rub or any other problems. The diameter is marginally bigger but width added only 1/4 overall (1/8 inch on each side). Speedometer is now closer to accurate than with the stock tires!
If it's the 2.2 (not sure since it's an LSI) check for evidence of oil around the timing belt cover. The 2.2 in particular needs new cam seals and the oil pump screws tightened by around this much mileage. If the timing belt was done, the seals and oil pump should have been at least checked. If not, this could be something to consider and have done with the timing belt. Also I believe the recommended timing belt change is 60k. I’m really not sure if all this applies to the 2.5 motors, so maybe someone else can confirm this info. Our 95 Legacy L just rolled over 110k and is running great. Only 1 front drive axel and 1 alternator repair have been needed and of course, all other regular maintenance
