Everything posted by Suzam
All the 99 Impreza models had it as an option, so you have to look around under the dash. It should be labeled and most likely stuffed up near the fuse box on the driver's side. The Code Alarm system was still used in the 99 Impreza (Alpine was used in the Legacy and Outback starting in that year) so it should be the square style remote.
Yes, you can have up to 4 remotes programmed for 1 car. It's a first in first out system. If you program in a 5th one the 1st goes away, and so on. Also I believe if you program 1 remote 4 times it wipes all the others out, so only enter each remote once. In the program instructions there is also a step for programming more than one fob at at time.
Either of those remotes will work. I just got an all gray button one from ebay ($15) for my daughter's '99 Outback which was exactly the same one for our '01 Outback. Ebay usually list the models and year that work. Just make sure it's a Subaru remote, BMW also used them and from what I've read the Subaru version doesn't always work the BMW's even if the part number was the same, so it may be true in reverse. Programming was easy too from the cars.101 instructions. UPDATE: I just did a search for "2000 subaru outback remote" and got plenty of hits for OEM remotes.
Make sure the handle is in the most forward position before you unlock the hatch. I had a 98 that you had to help the handle return to the forward spot before you could pull it back and lift the gate. It was caused by the common rust issue that's been discussed here before. As long as I moved it forward it was fine.
Whatever you choose, monitor the tread wear from center to outer edges of the tire. If you're wearing out the center faster, then your contact patch is smaller than the tread width. Ideal pressure for the tire would be even wear across the tread for the life of the tire. Over inflate too much and you loose more of the contact patch which is surprisingly small to begin with.
I have friends in Colorado just outside of Denver who routinely drive between 5,000 and 10,000 ft altitude. They use Michelin tires from Costco inflated with nitrogen on a Tribeca and run 32/30 front to back in the winter and 36/34 in the summer. The tread does wear quicker in the center because of "over" inflation but not really noticeable until the end of the tread life. They have close to 200k on the car now and have done this since new. They do raise the rear pressure 2lb when they carry more people or cargo for any distance. In Colorado, it seems like everything is a good distance from everything else. It seems like every time you get in the car you have to travel 50 one way miles just to get to were you want to go. At least that's how I feel when we visit.
It's not so much brand as circumference of the tires that's important. Subarus need no more than 1/4" difference to be sure no damage is done to the AWD system. Use the search here and you'll find a lot of info on tire matching. Do you feel the vibration in the steering wheel or is it more seat of the pants. If it's in the wheel you problem is in the front.
Anyone who wants to wire a OEM Subaru fog light on a late MY94 thru 97 Legacy can use this original instruction sheet for the wiring hook-up. Apparently you can't add a PDF file, so I've attached the jpeg files for all 4 pages.
These Outback wheels corrode like crazy for a couple of model years. My mother-in-laws 98 Outback (RIP) had issues with leaking. I had them cleaned up at the inner bead and they held fine after that. They would ALWAYS leak in weather temperature change from warm to cold during the fall and winter. After a good polish they worked fine. A friend with a 99 has the ugliest wheels you have ever seen. Would leak until they were cleaned up. Now they hold air fine too.
