I have a 1998 Legacy Outback and my clutch pedal had been "sticking" after being depressed so I ordered a new slave cylinder, hose, and gaskets (per the TSB that has been posted here elsewhere). Removing the old slave cylinder was easy but I ran into trouble when I tried to remove the rubber clutch hose. It came off the slave with no problem, but the other end is connected to a thin metal hydraulic line that connects to the master cylinder. I could not unscrew the small threaded nut that screws into the end of the rubber hose and while wrestling with this, I ended up breaking the metal line. So, a few questions:
1. Is is possible to buy more of this thin metal hydraulic line at autozone, napa, etc. or do I need to get it from the dealer? It has some very precise bends in it and I wasnt sure if this was a "custom" part. Also, are the connecting nuts a standard part or do I need to also get those from Subaru?
2. Should the nuts that connect this metal tubing to the master cylinder and to the rubber clutch hose be REALLY hard to unscrew? Is there a trick to unscrewing them (e.g. left-handed threads)? I tried to unscrew the broken remnant of the tubing that is left in the old hose just for the hell of it and all I did was round over the nut. I then tried to unscrew the end that connects to the master cylinder, and that, too, was super stuck and I stopped before I rounded over that nut. I won't try again until I get a flare wrench, but I fear that may not be enough.
Many thanks in advance!
Kevin
