northguy
Everything posted by northguy
  1. Welcome to the board. Hope to see more posts.
  2. I get wild fluctuations in oil presure when driving my 88 XT6. Even after a fresh oil change, the pressure can go from 80 psi to just above 0 psi. When I accelerate, the pressure climbs and then levels out at about 45psi and then drops. Is it common for the pressure to fluctuate like this if the oil pump is on its way out? Or could the pressure sensor be crapping out on me? Sometimes the lifters knock at the low reading, and sometimes not. Guesses?
  3. Ask him if he can drive it to you. That'll tell you volumes.
  4. Someone just posted a 2.7 for sale lately. Do a search - but first, check the belts. Miles is usually pretty accurate on his diagnosis. (It'd be a whole lot cheaper.) You may even want to contact Miles - he's a travelling mechanic who has done work in Ohio before.
  5. Try the search function on this. Enough has already been said.
  6. Just put a bigger sticker on that door. It'll look like new (or almost).
  7. Edrach sent me some stuff (can't remember the name right now) that is the cat's meow. It's much better than PB Blaster.
  8. I have 3 sets. 1 mags - street tires; 1 steel - winter studs; 1 steel - dedicated off-road tires.
  9. Brad, if this one is going to be your baby, why not just tear it down and build it back up right? Then you'll know there are no potentialities for failure.
  10. Hey. Welcome to the board. Have a look around.
  11. It'll show up. After all, it's on an island. Where could it possibly get to?
  12. There is no doubt that Mudrat makes a good product (when you can get him to come through for you).
  13. The Suzuki and the Tracker are the same car.
  14. You could determine which side of the glass the crack is on (inside or outside) and then cut, with a glass cutter, an arch from the bottom over top of it by an inch or two, all of the way back to the bottom. Break the cut you just made, and then the crack will be contained and not able to run any farther. Otherwise, you have a broken windshield which probably isn't much of an improvement over what you're replacing. Save your money and have a professional replace it next time.
  15. Find the "mini pad" in the air filter and follow the tube to the pcv valve.
  16. And why not Ohio? Or maybe Missouri? And hey Dr. be careful about the NWT. It's close to AK and the next thing you'll be saying is that nobody lives in that frozen tundra either. :grin:
  17. Nice job. I can only hope you can find a good 2.2 for my swap the same way you nabbed the rx.
