northguy
Everything posted by northguy
When I look inside of the rear wheel wells of my Brat I don't see any arches (inner wheel well coverings). Am I missing something?
5speed d/r swap question....
northguy replied to Beegeer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I don't want to seem like Daddy Warbucks, but I'd put in a new clutch set up while you're at it instead of something used. There's no sense in having to take it all back apart a few thousand miles from now. As to flywheel, I can't give you a definitive answer, but you could have the old one turned down also. -
Pug Wheels...and lug nuts
northguy replied to Do It Sidewayz's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ask what he wants for the drawer full. You could sell them in no time, if they are the ones with the washers attached. -
The alloys are such that the recesses are canted, they are sloped and the pug lug nuts have washers that are the same angle as the recess in the bolt hole. Hope that clears things up. -
Both sets are the same I am running. Regular lug nuts work fine on the steelies, but the mags require Pug nuts. If you find a suitable replacement, let us know. -
I use standard lug nuts on the steelies, and Pug lug nuts on the alloys. -
Buy the Impreza, and dedicate the EA for off-road exclusively. That way you can hammer it without regret.
Greetings !
northguy replied to agape's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Welcome to the board. -
Has anyone looked into welding the weak areas to reinforce them before installation?
xt6 ground clearance options?
northguy replied to northguy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ken's is radically higher. I'm not looking for that much gain, just enough to make it up my drive in the winter when I get home and haven't had the chance to plow yet. (sorry about the oversight on the typo). -
Bump - hoping for some input. -
With winter looming (it always is here), I'm thinking about options to create a bit more ground clearance with the xt6. I don't want to be plowing snow with the underside of it and would hope to have at least 6' of clearance, preferably more. It currently has had the air ride removed and conventional struts installed. What other options exist? Are there other struts that will gain some clearance between the body and tires to allow me to put larger tires on?
Signing off for a while
northguy replied to edrach's topic in Meet n' Greet. Your USMB Welcome Center
Did you score any good parts while you were on vacation? -
HBD, Austin, you young pup.
I was after him hard, also. But apparently he just couldn't pull it off. Maybe next year.
Who should I order stereo adapter from?
northguy replied to Todd in Seattle's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Or check cruthfield's online. -
If we can get Moosens to come, I'll bring down 30 lbs.!
The Museum of History and Art on 7th (I believe) avenue.
Wcss7- Missing Banners!!! address added
northguy replied to Qman's topic in Meet n' Greet. Your USMB Welcome Center
I like it. It takes a big person to own up to a mistake.
