northguy
Everything posted by northguy
Isn't thee just a fuse that controls the deployment of the airbag?
off-roading in Maryland
northguy replied to ineedone's topic in Meet n' Greet. Your USMB Welcome Center
Don't know where you are, but the Leanordtown, Lexington Park, St. Mary's area is good. -
New(to me:) 87 Subaru GL wagon - Engine Problems
northguy replied to Rodm21's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Try using a helicoil to repair the plug hole. Clean the carb to see if that improves the stall problem, and see whan the timing belt was changed last. (I assume yours is an ea82.) -
sticky lifters or whatnot? SEAFOAM!!
northguy replied to gunslinger's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I haven't tried seafoam, but MMO does work wonders. -
Better yet, fix it up, put it on ebay and don't put a reserve on it.
You could have been that stuck in my driveway. We got 8" yesterday.
Israeli Subaru club meeting
northguy replied to DL92SW's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Board name is rinatm. There is also a guy called israbrat. Good luck finding them. -
All you're missing is the girl from thee with the Brat. She's a board member. -
Get what you're comfortable with. There are enough members with enough know-how in your imediate area that a complete rebuild could be an afternoon's work, if you made the offer tempting enough.
Good to see you're still around.
My new find.. EA81 dune/swamp buggy
northguy replied to torxxx's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Your new ride must be uglier than a mud fence, but I'll bet it goes like hell. Take the amount of surface contact with the ground (let's say 2" x 7" per tire - that's 14" x 4 = 56 square inches. Divide by number of pounds. For grins let's say 2240 lbs. That's 40 psi). -
LSD oil additive in transaxle?
northguy replied to 85Sub4WD's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Jzab, welcome to the board. You'll find a bunch of your countrymen on this board.
If you're looking at toying with mods, you might consider a 2.2 Legacy motor and a 5spd d/r tranny. You can buy an adaptor from Mudrat79 and you'll have an rump roast kicking ride - go anywhere and fast to boot.
LSD Q? do i need the trans also??
Thanks for the correction. Hate to not credit the correct source. -
You could use your 3.9 tranny and just do the swap with the internals of the 3.7 and your existing 3.9 differential. There is an excellent write up in the USRM (I think it was Turbone who wrote it - please excuse me if I gave credit to the wrong author). If you switch transmissions you might have to look at different driveshafts also. So, if you're grabbing one thing you might as well grab it all. Be aware that tranny change mat require a clutch/flywheel change also. So grab that too.
