Everything posted by northguy
Help, Diagnosing Starter Problem 99 OBS
northguy replied to RudieValdes's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe whine noise you describe is the bendix going out. Mr. Dew is correct in his appraisal of it being a bit early for this to happen. He is also correct in his choice of : used (from a j/y) then rebuilt. And certainly replacement is a di-it-yoursewlf job. Caution: disconnect the starter first, just in case someone wants to start it while you're working on it.
1983 wasn't THAT long ago
What's up Doc? Welcome to the board. you've discovered problem solving at its best.
Hi LatinAmerica
Nice research, Morgan.
new member o2 sensor blues
northguy replied to fender's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWelcome to the board. How are things in good old Dubuque? (I grew up in Savanna, IL). Sounds like a loose wire. Good luck in the wire chase.
Hapy New year to yo all from Scotland
You're talking about building a snorkel for your intake? If you're doing a lot of driving in deep water, probably a good idea. If not, there's really no need.
Interesting finding after lift...
Belt dressing.
Hi LatinAmerica
Could it maybe be a WRX (since the w is directly above the s on the keyboard)? Welcome to the board.
see everyone in two months
Take your time going, but hurry back. Happy trails.
Fabricated a new bumper (255k)
Looks like you also need a good skid plate. Nice job - simple design.
HiHi, I'm New...1991 Subaru Loyale Questions...Please Help!!!
Welcome to the bard. Now is the time to ask yourself, "What do you want to do with this car?" If you want street mods or 4wd set up, there are 2 different paths to follow. What are you looking at?
Newbie checking in.
Welcome to the board. Is the "she" your subaru?
RalliTEK STi - Wrecked!!
northguy replied to ezapar's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOuch, both financiallyand emotionally (not to mention physically, I hope not).
i have a problem - need help fast....engine stop!
I believe Moshem is from a former "soviet block" country like Bulgaria, or somewhere over there. In our country, brand name of a gas drier is called Heet.
You could very well have debris in the jets in the carburator. Try running the rpms up to 4k or 4.5k for a few seconds the next time it dies and see if that helps to clear it out. If not, you may need to disassemble the carb and clean it.
SKA logo idea (edit: 2nd design in last post)
Kelly, put me down for a couple of each. Thanks for all of the hard work.
Questions about snow driving/snow tires
Wow! The learning curve for you is going to be high. Chains/ snow tires - get both. That way when you get stuck you can chain up and get out. Get a couple of 50# bags of sand for the back end, put it in 4wd and go like hell. Jam the brakes really hard at all stops and slide head first into whatever is in front of you. Whatever you do, don't take your foot off the pedal once you start sliding as you don't want to regain control or the ability to steer. If the back end starts to come around, don't steer into it; that will counter the slide. Instead steer away from it and floor it. That will spin you completely out of control. Don't pack a shovel either. You want to be as helpless as possible. Of course, don't follw any of the recommendations I have made as they are all hopelessly wrong. Good luck. (except about getting bith chains and snow tires, and the sand)
Who's in or near Ft. Jackson/Columbia, SC?
Isn't JWX from that neck of the woods?
4wd question
Back it onto gravel when you do it, or onto the grass.
Greetings!!!!
Welcome to the board. You might do an advanced search to see if there are any people from TN. I know of one or two in MO, but I'm not sure about your home state.
Here ya go JWX:
The subaru must be in employees' parking, and the black g-ride in the distance must be in upper management parking. I see the water is only up to midwheel on it.
EJ22 Performance Engine Kits
northguy replied to skytow's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDo they make a bolt up turbo for the 2.2?
WHOA! Susquehanna urethane mudflaps are STRONG!
A guy could probably use Kevlar, too.
Either one is fine, Kelly. Whatever you prefer. Do you need info from me for membership, or do you have enough?
Brat had no get up & go in the rain today! Whats up?
Mine is just the opposite. It runs like a raped ape in cool, damp weather. It's rainy and 35 degrees here and my Brat is running like a cat with turpentine on its butt.
changed my clutch today!
Kelly, you can bone up on my clutch when we do the conversion.
