northguy
Everything posted by northguy
POLL: should I get custom plates
northguy replied to subaru_styles's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Aren't they also called vanity plates? -
Best sparks plugs to run
northguy replied to djcracker's topic in Old Gen.: 80's GL/DL/XT/Loyales...
A search on this will give the full spectrum that has been run through several times. I'd personally go with NGK. -
i'll be moved to portland next month
northguy replied to subaru_styles's topic in Meet n' Greet. Your USMB Welcome Center
DOH! -
You'll be las than 10 min from Richie's shop. Go there, snoop around and see what he's got in hiding and report back. Good luck in your new locale. -
Any Recommendations For Window Glue?
northguy replied to NorthWet's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Stationary side glass is mounted in a rubbergasket that pulls in around a pinchweld or it is held in by butyl tape and urethane sealant, depending on make and model. -
If you have the rubber, make sure it is clean/ free of any debris before you attach the channel to the glass and be careful as you tap it into place (I'd recommend you lube the rubber up with silicone lubricant before you hammer it on. Or, is your new/replacement glass already attached to the channel? If so, it should just be a bolt-in operation. Again, test roll it several times to look for binding and adjustments. -
3M makes a two part epoxy especially for that application. Dry fit the window a couple of times first, rolling it up and down to ensure proper alignment before you put the glue in. -
Does "pug" stand for pugeot??
northguy replied to pwoens's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Also, be aware if lug nut concerns and center caps. -
N00b!
northguy replied to SS00Blue's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Welcome, and yes, this is a great board where you'll find a ton of info to help you with greater performance for your new soob. -
South-central Alaska soob meet-n-greet?
northguy replied to Snowman's topic in Meet n' Greet. Your USMB Welcome Center
Thanks, Brian. I know Jon (Battle-Wagon_Medic) knows of one , but he won't break loose with the info. -
And to top that, Alaska Towimg and Wrecking (ATW), the biggest boneyard in the state, closed its doors, crushed all of their cars and sent them to Japan as scrap metal. So Junkie, where (which one) is the yard in Wasilla? It can't be Knik T&W; they don't have anything even in the 80's. -
Been missing your input and perspective, Moosey. Welcome back.
WOW! With a title like tranny party and and invite to a tranny swap, I thought you were talking about something that may not be appropriate for this forum.
I doubt that you've really sold your last subaru; you'll sell more. (it's in the blood)
subaruclub.NET worldwide subaru forum
northguy replied to observer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm a grumpy ols cuss, too, but you're very welcomed here. -
No, mush bys are done with moose droppings. -
Welcome fellow Greatlander. Don't shy away from a M&G as there are some great people here who can give you some invaluable tips and we are all non-judgemental (at least those I've met). Snowman would have the best insight into the best place for parts - locally. AAA-1 is not the place. -
Hey, look what showed up in my driveway
northguy replied to Turbone's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Did the tooth fairy deliver it? Good to see you back. Did the surgery work out OK, or haven't you gone under the knife yet? -
What do you think of this color? (for the 78)
northguy replied to Kostamojen's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yeeowww! You'll never be mistaken for a different subbie. -
She's a pretty one.
