northguy
Everything posted by northguy
The day was goin' good... until....
northguy replied to Ratty2Austin's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I always consider it a good trip if you're not getting towed out. It's a bummer that you've got to replace your engine, but in some camps, that's the cost of playing in the woods. Fortunately, subaru engines are relatively inexpensive. But when all is said and done, you still will have had fun and wouldn't have traded the experiences for anything. -
Awww Yeah(some questions added)
northguy replied to Snowman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That's almost like milking a radiator. MOOOOO -
Anybody in East Guatemala
northguy replied to Stupidru's topic in Meet n' Greet. Your USMB Welcome Center
Yes, there are a lot of people in East Guatemala; they're called Guatemalans. They live there. -
What would be the best early Subaru to find
northguy replied to bigjim5551212's topic in Old Gen.: 80's GL/DL/XT/Loyales...
One word - Brat. But then, I'm biased. -
Kelly, I can't help with your question, but good to hear of your triumph over motor goblins. Next step = LIFT! -
That goes without saying. Your quality speaks for itself and your reputation is sterling. John, thanks again for your fine work and generous prices.
*...Is this a good price?...*
northguy replied to bakerman1's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Tell you what - If you drive it here, I'll give you a grand for it and a plane ticket home. -
what makes cars run bad when cold?
northguy replied to archemitis's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Buy a block heater instead and plug it in. -
pics of my new wagon finally
northguy replied to Meeky Moose's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Looks pretty sweet - nice score. -
1. Stock Hitachi 2. Not much real off road - putzing around - does fine OK on highway but no real dynamo - wish I didn't have to contend with IM, I'd have a weber on it in a flash
can a 6ft4in guy fit in a sube?
northguy replied to rallyruss's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If you bend the knees or cut off the head he'll fit in the trunk just fine. That's what you meant, right? -
Project 1982 Brat (Bobby meets Dirt) read last post
northguy replied to s'ko's topic in Old Gen.: 80's GL/DL/XT/Loyales...
cancer in the engine compartment around the strut towers. Almost all other rust is repairable. Strut tower rust is fatal. -
Loyale glass and DL/Gl gass is diferent and the install methods are dissimilar also. The removal of glass from a "glued-in" application is best done with a utility knife from both inside the car (cutting closely next to the glass and pinchweld) and then from the outside along the edge of the glass. The old wire method may work but a heated wire next to a piece of tempered glass will cause it to explode. The Dl/Gl glass may very well be rubber set (I don't rightly recall) but even if not so, you shouldn't be battlingthrough urethane - only butyl.
Nikfu - welcome to the board. We'll keep you posted on the next meet and greet. Good to see another Alaskan.
Good score, Rob. What are you going to do with them?
Since you are subject to IM inspections, a weber isn't an option, but you could send out a call for help to see if there is a Hitachi available on the board. I'd bet there are several. Also, you could check e-bay to see if there's one there. Depending on where you are in CA, you may be able to con another board member to help you with the swap, if you're not comfortable doing it yourself. Also, as to the clutch cable, WD 40 is good for displacing the water that may be in your cable - it's not good for lubrication, though. Hit the cable with ample WD 40, then lube it.
New to Subaru, Am I Blessed or Cursed?
northguy replied to Hudmud's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Hudmud, welcome to the board. There are several members in WI, and a bunch in the midwest. If you play around with the search function you will be able to dig up answers to most any question you may have about Subbies in the archives. You can also access the subaru repair manual for information. Good luck and welcome once again. -
04 BAJA Bumper DONE.......:)
northguy replied to mudrat79's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Very polished and professional. Great job. -
I'd love to upgrade to a weber and a new exhaust, but I've got to deal with stinking IM standards.
Wagons, how can you have over 2 million miles on various cars and not one of them is a Brat? - I know , the name , Wagons Only, but not even one Brat in the whole stable? That's unAmerican.
scuse me while i gloat over my new brat!
northguy replied to baccaruda's topic in Old Gen.: 80's GL/DL/XT/Loyales...
GOOOAAALLLLL!!!!! How could you go wrong with a Brat? Even if there were rust in the bed?
