northguy
Everything posted by northguy
BRAT Experts.... give me your $.02
northguy replied to subeman90's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It's like GD says:location is everything. In AK, any 4wd is worth at least $1500 if it runs decent. If the rust isn't too bad dicker with the person and get it down to around a grand. With mileage that low, it's a decent deal. -
Gotta 84 brat windsheild question.
northguy replied to Mr. Carb's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ok. What you have is a rigid chrome insert. This is good news. Stay with me here. Removal - 1. lower right corner is missing corner trim. Start there. With a cotter key puller (hook tool) or some pointed (blintly) tool, lift the top lip of the chrome up until it pullsout of the interlocking rubber. Slide the tool all along the bottom of the gasket. pull the trim out. Pell the corner trim out on the corner. Repeat this all of the way around, taking care not to kink the trim. 2. The gasket should be urethaned to the glass on all three surfaces. To remove the urethane, I make a special tool that makes it easy (get a windshield removal knife blade that has been broken and heat it up and bend it with a 1/4" lip on it. Bolt it to a piece of flattened conduit. bend the conduit to make a handle. Use your hook tool to create a void between the glass and the gasket or get a plastic stick from a glass shop - you'll need acouple of these anyway - slide the blade in until the lip drops over the edge of the glass. Pull the blade around the perimeter of the glass and you've cut 2/3 's of the urethane.) If you can't make the tool, carefully use a utility knife or a fillet knife to cut the urethane away from the glass. Then, using the flat plastic sticks, pry the rubber up and cut alongthe side of the glass the free op the sides. 3. Next, carefully cut the urethane on the inside from the glass and the gasket. A fillet knife works well here with some gentle pressure pushing out on the shield. 4. Now comes the fun part. One person inside/one outside. Inside, sit in the seat and put your feet on the shield. Push out slowly and evenly. Pushing too hardwill result in you catapulting the shield straight onto the hood. Outside, grab the shield on the way out. Wear safety glasses in case of glass flakes. clean up 1. The entire channel in the gasket MUST be free of old urethane and glass chips. Any debris left in there can and probably will result in breakage on installation. Use the plastic sticks to scrape out any debris. Wear gloves for all of this incase there are any glass chips. 2. Spray the gasket down with glass cleaner and wipe off. 3. Turn on ignition switch and set defrosters on high for a couple of minutes. Blow out any debris that may have gone in there. 4. While the shield is out, Armorall the dash and side posts. Inspect the gasket to make sure it is on the pinchweld. Look at the inside of the gasket, especially the top. See if there are two lips on the top. If so. roll the top of the gasket and about the first two inches of the sides off of the inside lip to ease installation. If not, make sure the gasket is firmly over the pinchweld. * note. The external edge of the gasket should be urethaned to the body. This aids in the structural integrity of the vehiclein the event of roll over and helps in avoiding leaks. installation 1. Again, inspect the groove in the gasket to make sure it is free of all debris. 2. liberally apply silicone lubricant on the external lip od the gasket around the entire perimeter. 3. slide the bottom edge of the shield into the groove in the bottom of the gasket and push the shield to your partner on the other side of the car. He/she should use a plastic stick to lift the side gasket up to allow theshield to start to eat in the side. Your bottom corner can be set in by keeping the corner about an inch up on the side and tucking the corner in the side gasket and then sliding it down into place. Use plastic slicks to free up any snags. 4. Use your plastic sticks to pry up the gasket away from the glass along the side, working the shield evenly as you go up. A couple of soft flet-hand slaps will help seat the shield as you go along. Do not pry against theedge of the glass. 5. The top corners will be the worst part. Sometimes it is easier to work the top lip from the middle to the corners. You can push the gasket up over the glass withthe plastic stick from the inside to get it started. Work the lip up over the glass until the shield is completely in and seated. 6. Trim. Put the bottom lip in first and use either your hook tool or plastic stick to pull the top lip over the trim. You can also get one side of the trim started on one side and feed it in, pushing it to the other and then deal with the two lips on the gasket the last few inches. Use plenty of silicone spray for this, taking care not to kink the chrome. 7. If you did have the double lip on the top, pull the gasket inover the pinchweld inside before you reinstall the trim. 8. Clean up and go drink a beer. -
I'm looking at your signature. Does your gasket have some chrome trim on it? If so, is it rigid chrome, or is it an insert bead? The latter of the two indicates an easier, but technically more difficult process. Let me know which type you have and I can make a better analysis. -
mpg decline
northguy replied to brompy's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
WOW! That's ridiculous. Really, find another mechanic. -
Welcome. If you have any questions about your Brat, this is the place to find the answers. Wealso look forward to any specialized knowledge you may have - it doesn't have to be in Subarus either.
Most shops will do it, but they will not guarantee that they will not break your shield in the process of installing it. They should charge you about $50 to install it (which is a rip-off as they charge $16 per hour for autoglass installation and if you're good at it , it takes about 1/2 hour). They really want to sell one of theirs to you. -
replaced a timing belt now no power?
northguy replied to josh long's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Since you didn't list what model it is, it's hard to say, but if you run a search on timing belt replacement, you'll find several complete write ups for different applications. That should help. -
Pull it in the garage, put an elephant tampon under it (or a large drainpan) and see if you can locate the point of leakage. It sounds like a bad seal or something that may have cracked in the cold. The recent fluid change is somewhat suspicious and the meager amount of miles, unless you've been doing some neutral drop burnouts, should indicate it didn't just suddenly die.
Why would you want to? 4 grand is hish enough to grab the peak of the next gear/ hold the powerband. Unless you just like fixing things.
need help picking new tires... which ones...
northguy replied to Rooinater's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The ssr's look like aggressive enough tread with the ability to still be managable on the raod. -
If you are going to trythe rope method that GD suggests, make sure to start at the bottom in the center and have someone to help you. Your partner should be outside, pushing slightly on the shield to assist in it going in and not shifting around. Pull the bottom rope across and up about an inch on one side , then do the other. Try to keep each side about even as you work toward the top two corners. A soft to medium open handed slap on the shield from time to time will help seat the shield. The top two corners are a bear and there is a twisting motion (kind ofa circular pull) with the rope that will help to get the corners in. A cotter key puller (a hook tool) will help tremendously with pulling the gasket in. Be careful not to hook the glass or have it between the pinchweld and the shield when your partner slaps the shield. If your gasket has a double lip on it, pull the first lip (the outer)all the way in, then work the second one (the inner) in after. Silicone spray works very well as a lubricant. WD40 is all right, but clean up is messy. It should be sealed with eurethane. If there is accent chrome in the gasket, insert it in the gasket before you bring it to the car. Good luck. -
Snow Fun
northguy replied to Hocrest's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Looks sharp. $200 is a deal. -
found something to drool over.. pics added..
northguy replied to Meeky Moose's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Nice score. Hope it pans out. -
That's an interesting roll cage.
Pic's of me 'roo's :)
northguy replied to GoldDiggerRoo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The white spokes are nice if you can find a decent set of center caps for them. -
mpg decline
I guess I wouldn't be too alarmed about 3 mpg given that the air is considerably colder /heavier in the winter, thus longer warm-up time, less efficiency burning, and more idling time before you take off. Also, the additives in gas in the winter (ethanol and oxygenated fuel) tend to reduce their efficiency also. But, keep an eye on it to see if it continues to slide. -
Engine transplant into the '85 Brat-update
northguy replied to Qman's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Wow, Qman. It would be cheaper to fly you up here to do a motor swap than to hire a local mechanic. Nice job. -
Weber carb.
Miles probably has a scale, but it probably only measures grams and ounces.
If you need a plow se up, I know a guy in Anchorage who can set you up with a new 61/2 foot plow, but it'll be spendy.
Transmission Questions
Golddogger, you've received sound advice from two of the most knowlegable sages on the old school side of the board. If you need help /questions answered in the process, Im sure GD and Turbone will be glad to walk you through it. You're in good hands here. And welcome to the board. -
i love synchros that work..
If a guy can't brag about his stable, what's the use in owning them? Looks like you've got a nice collection going. -
lost keys need locks and ignition now..
What do you have, a tuna-flavored key ring? -
Another plea to those waiting for parts from me
northguy replied to moosens's topic in Old Gen.: 80's GL/DL/XT/Loyales...
If you don't have access to a space heater, try using some of those chemical hand warmers. Throw a couple in between layers of clothing. -
It needs to be replaced, so when you take it to have it done, make sure to have those replacing it allow you to take pictures of it once they remove the bottom panel (cowling) covering the shield. It sounds like the shield either was set on top of the setting blocks, or they slipped off of them. Either way, it is a problem that was not a user-created problem. Back charge the dealer and let them settle with SOA.
